BenQ XL2411Z washed out look on cold start.
donel
Post by donel » 17 Jan 2015, 10:42
hi i dont know if anyone can help but this is really starting to get on my nerves :(
ever since owning this monitor i cant seem to get the colors how i like them.
there are many different profiles and people saying this setting and that but each time i start pc from being off all night the image will be cloudy or washed out. then i end up spending a hr or two messing with it each time trying to get it how i want. only for the next cold start to be washed out again.
anyone know why it would be like this after leaving pc off ? i have seen a few people mentioning about this issue and it takes a while for monitor to warm up. thing is its still the same 30minutes - 1hr in.
so if anyone has some help fool proof guide to help me it would be awesome :D
i use DVI-D connection , 120hz, no color profile . i don't use the benq one as it doesn't seem to stop the misty washed out look on cold start.
starting to think monitor might be broke .
masterotaku
Re: BenQ XL2411Z washed out look on cold start.
Post by masterotaku » 17 Jan 2015, 11:03
Haha, my XL2411Z behaves the same way. Colors, gamma, contrast, black levels, crosstalk, etc are worse for the first 30 minutes or so. There's nothing you can do, just let it get better by itself. My advice is that you should calibrate the monitor only after it's warm, because it will be in that state most of the time.
Now it's winter where I live and this happens every day, but in summer this phenomenon is rarer.
Monitor: Asus PG278QR
gamerscore
Post by gamerscore » 17 Jan 2015, 11:20
I ahve not experienced this before. Maybe because I live in a tropical country. :D
Intel i7 4770k @ 4.2Ghz
Gigabyte Gefore GTX 980 G1 Gaming
Benq XL2411Z
harrwang38
Post by harrwang38 » 26 Jan 2015, 05:17
This happens for my monitor as well. Using a good color profile helps a LOT while also having proper calibration.
gold
Post by gold » 24 Feb 2015, 15:18
Same, I just play a round of deathmatch and by the time its done everything is normal, Make sure you calibrate it after its warmed up! mistake i made haha
LaffTrack
Post by LaffTrack » 28 Feb 2015, 06:06
I did not even know this "warming up" to return to normal thing is a thing. Is this phenomenon distinct to this model or panel?
zefs
Post by zefs » 28 Feb 2015, 11:56
I've noticed that too but I thought it was the ambient lightning that affected it, not the panel itself.
Not a big deal though.
