Unable to install
chelch
Unable to install
Post by chelch » 30 Jan 2015, 21:55
Hello,
Trying to install lightboost but having issues. I am running the setup file. I go ahead and install a strobed and non strobed hz. When I reboot there is no lightboost icon in the system tray...almost as if nothing installed. I have tried to run as admin but that had no effect. Any help would be appreciated. Thanks.
Specs:
Monitor: BENQ XL2420T
OS: WIN& Ultimate 64bit
GPU: R9 290
Driver: 14.12 AMD Catalyst Omega Software
jaranis
Re: Unable to install
Post by jaranis » 23 Feb 2015, 16:11
Make sure you are running one of your strobed refresh rates you set at install. Sometimes my monitor starts up with a non-strobed refresh rate. Lightboost will be running whether or not strobelight.exe is running, but you can put a shortcut of strobelight.exe into your startup folder (%appdata%\Microsoft\Windows\Start Menu\Programs\Startup) so you can have the hotkeys at startup. I have the XL2420T too and you will see the Nvidia 3D light turn green once you are running a strobed refresh rate. Didn't even realize Lightboost was available on AMD cards until now..
jaranis
Post by jaranis » 23 Feb 2015, 17:35
Actually check this post sounds like it's impossible to unlock Lightboost with AMD cards as I originally thought.
http://forums.blurbusters.com/viewtopic.php?f=4&t=1876
