Hi guys,
I just bought "Acer GN246HL" and I'd like to lightboost it.
I got ToastyX Custom Resolution Utility but I do not think that it works...
How can I find out if I enabled lighboost?
Can you guys help me, please? THX
Acer GN246HL - LIGHTBOOST - ENABLED? (HELP)
- SW.png (174.68 KiB) Viewed 4551 times
Re: Acer GN246HL - LIGHTBOOST - ENABLED? (HELP)
Chief has the ACER GN246HL listed as "ToastyX not supported" in the 120Hz monitor list http://www.blurbusters.com/faq/120hz-monitors/
Maybe you can try some of the other methods for enabling Lightboost? http://www.blurbusters.com/zero-motion-blur/lightboost/
