Hey everyone,
I was told to post this here!
So I was finally able to order my BenQ XL2411Z and hopefully if arrives soon. But before it comes I just wanted to figure out what I should know. I read different things and watch video but they all soft of give me different advice on what to do so I'm not too sure. I bought it from staples in Canada so if anyone has bought from them before could tell me if it came with v1 - 4 that would be great. So right now I mainly play a lot of CSGO and my old Samsung monitor broke so I needed a new one.
I was reading on 120hz + light boost to get rid of any motion blur and ghosting which sounds great but then I have other people saying to use 144hz to get the 1ms response time.
For argument sake if 120hz + light boost looks better but 144hz is better for csgo, are there profiles I can make to switch between the two?
IF there is any Sticky or how to for noobs on here and I missed it, I apologise. Just link and I'll gladly read it!
BenQ XL2411Z
Re: BenQ XL2411Z
Okay so my monitor came and I have it on 120hz and I'm trying to get rid of the ghosting..I did the 1350 trick but it isn't showing up on my resolutions. Any help?
Re: BenQ XL2411Z
Did you forget to use the pixel clock patcher?
Patch must be used if the pixel clock exceeds 330.00 MHz over DVI-DL.
I do not know about displayport.
Re: BenQ XL2411Z
Yes I did. Okay so I got that resolution to show up but everything looks terrible. I'm not sure what I did wrongFalkentyne wrote:Did you forget to use the pixel clock patcher?
Edit: found out what i did wrong..There still seems to be quite a bit of ghosting ? Can some help me out
