Acer XG270HU ULMB mode?
Is it possible to enable any kind of strobing display or low-motion-blur mode on the XG270HU (the FreeSync version of the XB270HU)?
Edmond
Re: Acer XG270HU ULMB mode?
I have no clue. Sorry.auxy wrote:Is it possible to enable any kind of strobing display or low-motion-blur mode on the XG270HU (the FreeSync version of the XB270HU)?
But i just wanted to correct that its not the "freesync" version of anything. Its a TN panel, which is a completely different story than the IPS the xb270hu has.
No, there's no motion blur reduction of any kind. From the TFTCentral review http://www.tftcentral.co.uk/reviews/acer_xg270hu.htm:
Unfortunately there is no Blur Reduction mode available from this screen so you are not able to reduce perceived motion blur further using a strobe backlight. See the relevant section in our BenQ XL2730Z review for an idea of how much blur can be eliminated using a strobe backlight system.
Thanks for the reply! Shame about the lack of blur reduction. ( ;∀;)itee wrote:No, there's no motion blur reduction of any kind. From the TFTCentral review http://www.tftcentral.co.uk/reviews/acer_xg270hu.htm:
