XL2420G Vs XL2430T playing Csgo competitive
donkus35
Post by donkus35 » 17 Aug 2015, 15:25
Looking Monitor For playing Csgo competitive
XL2420G vs XL2430T which one do you prefer for Csgo competitive ??
My previous Monitor is Eizo Fg2421. :D
Falkentyne
Re: XL2420G Vs XL2430T playing Csgo competitive
Post by Falkentyne » 17 Aug 2015, 16:19
They are both basically the exact same in XL2420G's "Z" mode, as long as you set the black equalizer to 0 on XL2430T if you are using this monitor instead (this is black equalizer 2.0 which is available in standard mode and is a huge downgrade from the old black equalizer which just affected gamma on dark shades). For XL2420G in "Z" mode, preferred is use standard mode, blur reduction, 120hz, contrast 40, brightness 100, Vertical total 1500 tweak, adjust strobe duty and strobe phase (service menu) to your liking.
XL2420's Gsync mode has gsync and CS:Go can easily maintain framerate=refresh rate so you won't need gsync; just use 120hz blur reduction, Vertical Total (VT) 1500 tweak with AMD/Nvidia pixel clock patcher (not needed over Displayport), and of you go...
donkus35
Post by donkus35 » 18 Aug 2015, 14:31
Falkentyne wrote:They are both basically the exact same in XL2420G's "Z" mode, as long as you set the black equalizer to 0 on XL2430T if you are using this monitor instead (this is black equalizer 2.0 which is available in standard mode and is a huge downgrade from the old black equalizer which just affected gamma on dark shades). For XL2420G in "Z" mode, preferred is use standard mode, blur reduction, 120hz, contrast 40, brightness 100, Vertical total 1500 tweak, adjust strobe duty and strobe phase (service menu) to your liking.
is it worth to upgrade from eizo fg2421 to xl2420g ??
Falconk27
Post by Falconk27 » 18 Aug 2015, 16:24
I would not recommend the xl2430t. I just got one and it has been a huge hassle, colors out of the box are terrible and to get brightness to an acceptable level required a lot of time and research, I think I'm jsut goiing to return mine and go for a 2420
Falkentyne
Post by Falkentyne » 18 Aug 2015, 18:01
For XL2430T, turn the digital vibrance up or down 1 notch from the default. Default value is incorrect.
Set black equalizer 2.0 to "0".
