Why have I never experienced stutter or tearing on my CRT?
CathodeSwagTube
Post by CathodeSwagTube » 20 Nov 2015, 15:08
I've been using an UXGA CRT at 85hz for 10 years now, with many different GPUs, and I have at several occasions throughout these years had bad FPS to the point where I can't play a game (dropping under 30-40). However, I can't ever remember experiencing problems with tearing or stuttering. Do CRTs not get these? Why?
Shouldn't 85hz with 60fps result in frames being displayed twice, and stutter?
Perhaps stutter just looks different on a CRT?
spacediver
Re: Why have I never experienced stutter or tearing on my CR
Post by spacediver » 20 Nov 2015, 17:34
Load this up on chrome. Do you see image doubling?
http://www.testufo.com/#test=framerates-text
Q83Ia7ta
Post by Q83Ia7ta » 20 Nov 2015, 17:38
vsync
CathodeSwagTube
Post by CathodeSwagTube » 20 Nov 2015, 18:43
spacediver wrote:Load this up on chrome. Do you see image doubling?
I see stuttering in both texts. I've never noticed it in games though, unless they drop to under 30fps maybe.
(However I have Aero turned off and like 80 tabs open in chrome that I can't currently close, so that test might not work. The bars in the smooth demo are tearing up a bit for me http://www.testufo.com/#test=stutter&de ... 12&pps=720)
I generally have vsync off, but it varies. Over the last ten years I've never seen vsync make any difference in any game, so I've just started to ignore whether it's on or off.
sharknice
Post by sharknice » 21 Nov 2015, 21:45
Stuttering and tearing are harder to notice if you haven't experienced stutter and tear free gaming.
I didn't notice it much until I used gsync, I notice stutters and tears immediately if I don't use gsync now.
Q83Ia7ta
Post by Q83Ia7ta » 22 Nov 2015, 04:30
I didn't notice any tearing playing 144Hz with stable 250fps until I played 200Hz for a while and went back to 144Hz.
CathodeSwagTube
Post by CathodeSwagTube » 23 Nov 2015, 03:11
Perhaps I just don't notice stutters that are less than 3 duplicate frames on 85hz. That'd explain why I never see it while my fps is over 40.
What's the acutal difference between stutters and micro-stutters though? Just the amount of duplicate frames?
