Can connection affect input lag?
urut
Post by urut » 22 Nov 2015, 14:38
Hello, i've got simple question. It's any diffrence between DVI, VGA, and HDMI connected to benq xl2411z in input lag? Is any diffrence? :D
Q83Ia7ta
Re: Can connection affect input lag?
Post by Q83Ia7ta » 22 Nov 2015, 16:23
Yes but I guess it's less than 1 ms. You will never notice.
Kirayamato
Post by Kirayamato » 22 Nov 2015, 16:44
Q83Ia7ta wrote:Yes but I guess it's less than 1 ms. You will never notice.
which one is the fastest display port?
urut
Post by urut » 22 Nov 2015, 16:57
+1, i want to know this too :D
Cuz i testing now all of connections, and idk is placebo effect or not, but with hdmi i've got better picture quality than in others (maybe placebo) and with VGA i feel more responsive (maybe placebo too).
Is VGA a fastest? With least amount of input lag?
Sparky
Post by Sparky » 23 Nov 2015, 14:31
It could affect input lag, but whether it DOES depends on the monitor, so I'd rather not speculate. You can usually see what interface was used when reviewers publish input lag tests though.
VGA would be fastest...if you used it with a CRT, but an LCD has to convert it back to digital anyway, so probably not.
