hi can someone tell me what are the lowest input settings or best/easiest settings are?
to get better ingame
like these
http://i.imgur.com/aB3Jugj.jpg
cs:go nvidia settings ?
Sparky
Re: cs:go nvidia settings ?
What are your framerates? By default there's a 300fps cap, if you don't fall below that there really isn't much you can do to improve latency via game settings.
abcpeppi
most of the times i got 300 or more but can i change some settings in nvidia ?
or some programs like atuner but this doesnt work on windows 64 and is very old
- lexlazootin
Just leave the control panel how it is, anything you can do might make it worse.
Nvidia knows what they are doing.
.kernel 0x000
well you have maximum prerendered frames at 1 so you're good. Also I hear that if you set the desktop scaling from being done on the gpu to being done on the monitor, it can reduce some input lag.
Sparky
Max prerendered frames only matters if you're gpu limited, in which case you have extra lag regardless of what it's set to. If you're GPU limited, you can cut a frame or two worth of input lag by capping framerate just below your minimum framerate..kernel 0x000 wrote:well you have maximum prerendered frames at 1 so you're good. Also I hear that if you set the desktop scaling from being done on the gpu to being done on the monitor, it can reduce some input lag.
As for scaling, I haven't tested that, but I suppose it depends on the monitor.
