My fresh Asus PG248Q 180Hz experience
Q83Ia7ta
Hello! I bought Asus PG248Q two days ago and I wanna share some my experience with this monitor.
This monitor compared with other 144+ Hz TNs I saw has good overdrive at 180Hz. Good (if not best) overdrive is by G-sync. There are 3 overdrive settings. OFF/ Normal / Extreme iirc.
I can't say how good colors are but default settings are definitely better than XL2411T, XL2411Z,XL2430T by BenQ I used.
Looks like panel is new and same as in ASUS MG248Q - AUO M240Q007 V0. By ASUS MG248Q review I can't see any improvements over default panel of almost all 24" TN 144Hz monitors - AUO M240HW01 V8. May be I'm wrong.
180Hz isn't perfect as I expected. Some moire appears at 180Hz. Looks like small thin transparent horizontal lines every ~10 pixels that move slowly all over the screen. It's playable but bothers me. Never had them at ZIS DVI board (with AUO M240HW01 V8) at 220Hz.
144Hz is ok. I've talked with other PG248Q owner from other country and he has same moire. So it's not a defective panel/monitor. I'm looking how it can be fixed. Free to suggest.
http://imgur.com/a/1O6E7
I haven't tried G-Sync, ULMB, 160Hz & 170Hz yet.
I can't recommend it for upgrade of current 144Hz panel for regular players because 180Hz isn't great with this moire and PG258Q (native 240Hz on new 25" TN panel) coming in 2-6 months.
You can ask your questions here.
Also fresh review at pcmonitors.info: https://pcmonitors.info/reviews/asus-pg248q/
- lexlazootin
Re: My fresh Asus PG248Q 180Hz experience
yea, funky shit seems to happen when you push a panel past 120~
I have one of the ZIZ boards and although 250hz is freaking amazing, the panel kinda lets it down.
I really can't wait for the Native panel to come out
Falkentyne
Q83Ia7ta : You get moving horizontal lines at 180hz?
So is that the same as the "non moving" scan lines you get on the M240 (and M270HTN01.0 for XL2720Z), except they are stationary, when using "VT tweaks (VT 1500 range) or Lightboost 2D mode (e.g. VG248QE)?
Q83Ia7ta
It's more like waves than lines. They are different from scanline-like lines that can appear and disappear on 144Hz monitors. On 170Hz all is ok.Falkentyne wrote:Q83Ia7ta : You get moving horizontal lines at 180hz?
Q83Ia7ta
Added at first post imgur album how 180Hz artifacts looks like. Far from perfect photos. But they more noticeable at dark color and clearly visible at games :/
Falkentyne
Oh I understand that type of pattern now! Slow moving alternating lines. Reminds me of some sort of electrical interference or some sort of something reasonating with something else (you know what I mean).
- masterotaku
I got that same pattern on my BenQ XL2411Z with some custom resolutions. Changing the Vertical Total a bit fixed it.
But I don't think you can create a custom 180Hz resolution. My Dell S2716DG doesn't like custom refresh rates or timings, for example.
Monitor: Asus PG278QR
Q83Ia7ta
I can +/- 1Hz or +/-2 VT. But no changes.masterotaku wrote:I got that same pattern on my BenQ XL2411Z with some custom resolutions. Changing the Vertical Total a bit fixed it.
Q83Ia7ta
Btw I also had that signal lost several that described at pcmonitors review. For me it was not just signal lost. PC just hangs - Num Lock LED stops react on toggle
May be driver update will fix it. This "signal lost" happens only sometimes if I change refresh rate at OS.
charlychad
Hi Q83Ia7ta,
Did you find how to fix your problem at 180 hz?
I'm still on a 144hz monitor but if this 180 hz screen have still some problem, i prefer to stay on my 144.
