Adjusting BENQ Blur Reduction and DyAc (Dynamic Acceleration) including
Blur Busters Strobe Utility. Supports most BenQ/Zowie Z-Series monitors (XL2411, XL2420, XL2720, XL2735, XL2540, XL2546)
Spawnraven
Post
by Spawnraven » 28 Sep 2016, 07:06
Hi, I recently purchased a new Benq Zowie XL2411 but the Strobe Utility keeps telling me "No Compatible Benq Monitors have been detected"
Any help is appreciated, thanks
Manzu
Post
by Manzu » 30 Sep 2016, 14:40
Hey, same problem here. I've install the driver from the cd and to be sure i've check in device menager on monitor and it says ZOWIE XL LCD (Digital). Runned with administrator still same problem. Any help is apreciated.
Q83Ia7ta
Post
by Q83Ia7ta » 30 Sep 2016, 16:29
I'm sure software is outdated and don't support this new monitors. Find author and email him.
Falkentyne
Post
by Falkentyne » 30 Sep 2016, 16:44
Strobe utility doesn't support monitors with new firmware code. But firmware is the exact same as XL2411Z V004. But Zowie updates this to V005. Please use service menu to make strobe changes. Besides, service menu is more powerful. You can use strobe adjustments with Single Strobe=OFF at 100hz+ refresh rate. Single Strobe On is only required for refresh rates lower than 98 hz. You can also use Strobe Phase =100 if you are *NOT* using Vertical Total tweaks. If you are using VT tweaks, maximum strobe phase will be limited to 100 (60hz), 59 (100hz), 49 (120hz), 46 (125hz), 70 (85hz, VT 1501 only).
Margusx
Post
by Margusx » 14 Nov 2016, 02:41
Any chanche to get zowie 2411 firmware or its too early everybody can dump firmware easy on linux
tamacuki
Post
by tamacuki » 23 Nov 2016, 03:21
Some problem here and my old monitor XL2411z has V004-20141205 firmware. I used Blur Buster Strobe Utility before, but now my monitor is not recognized. I think the problem is related to the drivers incompatibility (Zowie).
Q83Ia7ta
Post
by Q83Ia7ta » 23 Nov 2016, 03:34
btw I guess modified monitor ID at EDID can make Strobe Utility work with new Zowies. It's software only method. Anyone tried it?
stele
Post
by stele » 27 Nov 2016, 05:07
Falkentyne wrote:Strobe utility doesn't support monitors with new firmware code. But firmware is the exact same as XL2411Z V004. But Zowie updates this to V005. Please use service menu to make strobe changes. Besides, service menu is more powerful. You can use strobe adjustments with Single Strobe=OFF at 100hz+ refresh rate. Single Strobe On is only required for refresh rates lower than 98 hz. You can also use Strobe Phase =100 if you are *NOT* using Vertical Total tweaks. If you are using VT tweaks, maximum strobe phase will be limited to 100 (60hz), 59 (100hz), 49 (120hz), 46 (125hz), 70 (85hz, VT 1501 only).
I started from this guide that seems outdated:
https://m.reddit.com/r/pcmasterrace/com ... mpact=true
When i arrive to this utility it gives the "Firmware Unsupported" error as you confirm in your post.
I have this monitor and I understand to be very ignorant. Any help to be able to properly calibrate it for fps gaming would be appreciated.
Pajas
Post
by Pajas » 26 Dec 2016, 09:59
@stele, Hey, I am in the same exact situation as you were a month ago, did you solve it?
stele
Post
by stele » 26 Dec 2016, 11:08
Pajas wrote:@stele, Hey, I am in the same exact situation as you were a month ago, did you solve it?
Unfurtunately no. I aM sorry. The First one with news... Post it here
