BenqXl2540 BlurBusters UFO test
Doublemeter
Post by Doublemeter » 13 Feb 2017, 12:12
at you guys who have the new benq xl2540 out there. i have a problem. i do not get the 240hz ufo in the test. it stays at the 144hz ufo. does this test only go till 144hz? pretty new to the website. https://www.youtube.com/watch?v=qYbG3Fk ... e=youtu.be thi guy apparently has 240hz blur busters what am i doing wrong. I have the newest chrome browser so that cant be the problem. thx guys
Re: BenqXl2540 BlurBusters UFO test
Post by Chief Blur Buster » 13 Feb 2017, 14:08
TestUFO stuck at 144Hz instead of 60Hz?
You might be still running 144Hz refresh rate.
Check your refresh rate isn't still 144Hz:
http://windowsreport.com/fix-screen-pro ... indows-10/
Also, not all display inputs supports 240Hz. Make sure you're using the correct cable, too.
Q83Ia7ta
Post by Q83Ia7ta » 14 Feb 2017, 05:07
Chief Blur Buster wrote:Also, not all display inputs supports 240Hz. Make sure you're using the correct cable, too.
Even not all videocards that have displayport supports 240Hz. GTX 580 can't, GTX 950 can do 240Hz.
StrobeMaster
Post by StrobeMaster » 14 Feb 2017, 05:33
Actually, all inputs the BenQ XL2540 has (DP, HDMI, DVI-DL) support 240Hz, but the operating system might not, in which case Toasty's tools help (if the graphics card is up to it). I can only speak for F/W version V2 though. I use this monitor successfully with a pretty old graphics card (AMD Radeon R7 250X which is basically a HD7750) and an even older driver (Catalyst 13.1) via DVI-DL. BTW, I remember having had some problems with DisplayPort in the beginning (AMD Radeon RX460, latest drivers), which seemed be less reliable in detecting that the monitor can go 240Hz (and doesn't have FreeSync, etc.). But this is not so unusual in my experience - whenever I have problems with the video interface, it is always with DisplayPort.
demannu
Post by demannu » 27 Feb 2017, 01:20
Pretty sure he was referring to the cables being used and not the ports being used.. i.e hdmi 1.4 as opposed to 2.0
Interesting though, im using the supplied displayport cable.. (no option for 240hz only 144hz) might will pickup a hdmi 2.0 cable tomorrow if I can't get it working tonight and see how I get on..
demannu
Post by demannu » 27 Feb 2017, 04:25
managed to get mine working @ 240hz using display port and is also shows 240fps on the ufo test.. however every now and then the setting keeps reverting back to 144hz.. still going to pickup a hdmi 2.0 tomorrow to see if its more stable..
