1000fps cameras in smartphones! Good for display analysis.
New smartphones are coming that can shoot at 1000fps!
Sony 1000fps Smartphone Camera Sensor
This brings a new dimension to citizen display testing -- users & bloggers able to do high speed videos for things like input lag testing (like GSYNC Preview #2) to analyzing display response behaviour (like High Speed Video of LightBoost).
Even display manufacturers can benefit from using simple high speed video in analyzing their display response behaviours, too.
High-speed videos are also very useful for rudimentary LCD GtG analysis (at the coarse millisecond granularity) on a full-screen basis -- as found in Electronics Hacking: Creating a Strobe Backlight which some of our users (and even a few display manufacturers) followed to experiment with LCD blur reduction modes. Full-screen analysis of LCD GtG behaviours is extremely useful for several use cases including scanout analysis and overlapping-refresh-effect analysis (in addition to point testing, via the usual photodiode oscilloscope method -- for accurate GtG response graphs).
Cheers,
Cheers,
spacediver
Re: 1000fps cameras in smartphones! Good for display analysi
This is insane. My casio exlim zr700 can do 1000 fps, but only at a resolution of 224x64 .
1000 fps in full HD is getting into phantom camera territory.
Sparky
I wonder what duration it can manage, if it has a global shutter, etc.spacediver wrote:This is insane. My casio exlim zr700 can do 1000 fps, but only at a resolution of 224x64 .
Not global, alas. But it uses high-speed readout:
http://www.sony.net/SonyInfo/News/Press ... index.html
Also, this is the image quality of the 1080p at 960fps in this new smartphone sensor:
This is a smartphone sensor?
I'm actually pretty impressed, this used to be the territory of Phantom cameras costing $10K+ ....
Even if I can only record a 5 second clip, this will be excellent for display-analysis and millisecond-accurate lag-testing applications (GSYNC / FreeSync lag testing, using the modified mouse technique). It's going to be great for display analysis too, including the high speed video of lightboost.
I think that before 2020, and even maybe by end of this year, iPhones and GoPros will do 1080p+ at 1000fps. Tiny smartphone lens won't be able to capture as much light as a large-lens Phantom, but for outdoor daylight use, it should be acceptably sufficient given modern backside-illuminated sensors at 1/1000sec exposure per frame.
Sparky
That video is a bit concerning, the slow motion portions of the video were at most a few seconds of playback at 15fps. Testing latency with one of these is going to be mighty tedious if you only have a ~50ms window in which to capture your event.
This is indeed a consideration, however:
You can get a longer time window if you use a lower resolution. That's more than sufficient for testing with a mouse -- you don't need full 1080p resolution for that. But yes, if you were limited to 50ms, that would make lag testing an issue unless I used some kind of a lag-less electronic trigger (mouse button press initiated the high speed video instantly.
For high-resolution GtG analysis of a display via high speed video -- 50ms is quite plenty of time for the High Speed Flicker test -- http://www.testufo.com/flicker -- since refresh cycles are ~4.1ms at 240Hz. (~8.3ms for 120Hz, ~16.7ms for 60Hz). A great GtG analysis of a LCD display is the High Speed Video Of LightBoost.
RLBURNSIDE
Stunning.
Hopefully more people will start realizing that < 120 fps is too low for adequate image clarity.
brooky
My God, technology is just amazin! I can't wait to buy a new smartphone.
Välj en av alla våra casino sidor och spela på de bästa sidorna som finns på nätet. Alla våra casinon är trygga för svenska spelare och du kan spela med eller utan spelpaus. Vilka spel gillar du? Testa kortspel på casino om du inte gjort det än!
