ATTN: Zowie XL2735 owners: [Test FreeSync 'Hack']
Falkentyne
Post by Falkentyne » 04 May 2017, 16:19
Please go into the service menu and disable DyAc (Benq blur reduction) and see if FREESYNC becomes available on an AMD Video card! Thank you very much!
Service menu:
power off (Must have been powered on previously, not unplugged), hold button #4 for 5 seconds, power on, and release button 4 after the display appears).
daniel
Re: ATTN: Zowie XL2735 owners: [Test FreeSync 'Hack']
Post by daniel » 30 May 2017, 08:16
For me it is working perfectly, why do you ask about it?
To want to, is to be able to.
Post by Chief Blur Buster » 30 May 2017, 10:13
You used FreeSync on your XL2735?
Falkentyne
Post by Falkentyne » 30 May 2017, 16:31
daniel wrote:For me it is working perfectly, why do you ask about it?
Whoa Daniel, this is amazing news if true...
can you PLEASE Confirm that you are using an XL2735 *AND* Freesync is enabled and working in the AMD Drivers?
This monitor is over $600 so I can't afford to buy one just to test it.
Can you possibly take a screenshot of the control panel with the monitor name and Radeon settings/freesync tab open?
Also is DyAC enabled or disabled?
Falkentyne
Post by Falkentyne » 31 May 2017, 22:28
Hmm, no response from Daniel...why do I have a feeling ........
peanutvoid
Post by peanutvoid » 15 May 2018, 06:04
Hey,
I own this monitor and I have tried most things to try to get it to work and it just doesn't want to work for me at all, the free-sync option is grayed out in the driver settings.
Falkentyne
Post by Falkentyne » 15 May 2018, 23:00
peanutvoid wrote:Hey,
Did you DISABLE DyAc in the service menu and then POWER OFF and power on the monitor completely?
You have to do that.
Just disabling DyAC and trying to enable freesync won't work.
peanutvoid
Post by peanutvoid » 16 May 2018, 05:02
Yes I did. I turned off DyAC, turned off the monitor and turned it back on again, tried rebooting the PC as well.
I tried different Display port 1.2 cables an dports on my GPU, I tried using different custom resolutions or refresh rates. Nothing worked. The GPU I'm using is a R9 380X with the latest drivers.
Falkentyne
Post by Falkentyne » 16 May 2018, 05:53
Thank you. Someone mentioned the freesync ID is probably in the displayport spec hardware in the monitor itself.
It would probably 100% work with the "freesync over HDMI" hack however, but you have to look up those posts written here and on guru3d forums. The scaler 100% supports freesync so its almost a slam dunk that it would work.
peanutvoid
Post by peanutvoid » 16 May 2018, 08:53
I'll definitely be sure to look into it when I find the time, thank you!
