Good news,
I'm updating Blur Busters Strobe Utility to support the new 240Hz BENQ monitors (XL2540, and probably XL2546 too). And adding compatibility to XL2730Z as well.
If you have any Benq/Zowie...
XL2730
XL2735
XL2430
XL2540
XL2546
...I'd like you to help me beta-test the newer version of Blur Busters Strobe Utility.
Contact me squad[at]blurbusters.com
Thanks,
Strobe Utility for 240Hz Zowies for BETA TESTING
Re: Strobe Utility for 240Hz Zowies for BETA TESTING
EDIT: That was quick!
Within minutes, I received 3 beta testers now, still accepting more.
I'll reply to your emails within 24 hours.
Eight beta testers.
I will have an early beta this weekend, keep tuned.
Betas have now been sent out.
da-k1ng
Hello,
I want to test the Beta Software, have a XL2730Z from BenQ.
da-k1ng
da-k1ng
Version 1.6 beta will be out sometime later this summer -- this will finally add XL2730Z support and fix the XL2540 Persistence scaling (works but inverted/swapped labels for Persistence).
We're focussing on another important Blur Busters project (temporarily)
- PanzerIV
Hi Chief, I've sent an email a week ago to the adress you gave but haven't received a reply yet so I thought I might try to contact you through here instead.Chief Blur Buster wrote:Version 1.6 beta will be out sometime later this summer -- this will finally add XL2730Z support and fix the XL2540 Persistence scaling (works but inverted/swapped labels for Persistence).
I was wondering why the v1.6 Beta wasn't downloadable publicly on the website and that we must absolutely contact you to get it? I was so happy when BenQ exchanged at no fee my XL24** for a XL2730Z but really sad at the same time when I saw that the utility wouldn't work anymore with my monitor as I remember it did make quite a difference.
Do you know also if we can still use the (Vertical 1350 Trick) with a 2560x1440 monitor or that trick was only good for 1920x1080 resolution?
Intel i5 8600K @ 5.0Ghz | EVGA GTX1080 8Gb @ 2100Mhz | MSI Z370 Krait Gaming | Corsair 2x8Gb DDR4-3200
Acer XB271HU + Shimian QH270 "1440P IPS"
