Disablo 3 update and G-SYNC
The Diablo 3 update does support g-sync, but only if you enable v-sync. I just thought I'd give a heads up to anyone wondering why it wasn't working. I initially had v-sync off and g-sync wasn't engaging. Unfortunately with v-sync on you are capped at 60 FPS.
Re: Disablo 3 update and G-SYNC
That is very strange and I'm getting the same behavior. I tried forcing vsync through nVidia Inspector but it still didn't work.TSM wrote:The Diablo 3 update does support g-sync, but only if you enable v-sync. I just thought I'd give a heads up to anyone wondering why it wasn't working. I initially had v-sync off and g-sync wasn't engaging. Unfortunately with v-sync on you are capped at 60 FPS.
hashtonkutcher
Did it work correctly before the latest patch? I'm going to test this game out later...
Yes, before the update it worked with v-sync off.
Interesting.
Could you post details about this in the hall of shame thread?
http://forums.blurbusters.com/viewtopic.php?f=2&t=329
Monitor: Gigabyte M27Q X
hashtonkutcher
Just tried it, can confirm everything in OP.
How does one actually know that g sync is not 'engaging' in a game. Jw
You can press the menu button on the monitor and it tells you if it's running in normal mode or G-sync mode right on the OSD.annisman wrote:How does one actually know that g sync is not 'engaging' in a game. Jw
hashtonkutcher
I submitted a support ticket on this issue I'll let you know how it goes.
So that will change as you load into a game ?nimbulan wrote:You can press the menu button on the monitor and it tells you if it's running in normal mode or G-sync mode right on the OSD.annisman wrote:How does one actually know that g sync is not 'engaging' in a game. Jw
