Page 1 of 2
Disablo 3 update and G-SYNC
Posted: 26 Feb 2014, 01:16
by TSM
The Diablo 3 update does support g-sync, but only if you enable v-sync. I just thought I'd give a heads up to anyone wondering why it wasn't working. I initially had v-sync off and g-sync wasn't engaging. Unfortunately with v-sync on you are capped at 60 FPS.
Re: Disablo 3 update and G-SYNC
Posted: 26 Feb 2014, 15:52
by nimbulan
TSM wrote:The Diablo 3 update does support g-sync, but only if you enable v-sync. I just thought I'd give a heads up to anyone wondering why it wasn't working. I initially had v-sync off and g-sync wasn't engaging. Unfortunately with v-sync on you are capped at 60 FPS.
That is very strange and I'm getting the same behavior. I tried forcing vsync through nVidia Inspector but it still didn't work.
Posted: 28 Feb 2014, 20:26
by hashtonkutcher
Did it work correctly before the latest patch? I'm going to test this game out later...
Posted: 28 Feb 2014, 21:06
by TSM
Yes, before the update it worked with v-sync off.
Posted: 01 Mar 2014, 01:54
by Haste
Interesting.
Could you post details about this in the hall of shame thread?
http://forums.blurbusters.com/viewtopic.php?f=2&t=329
Posted: 01 Mar 2014, 03:49
by hashtonkutcher
Just tried it, can confirm everything in OP.
Posted: 01 Mar 2014, 10:19
by annisman
How does one actually know that g sync is not 'engaging' in a game. Jw
Posted: 01 Mar 2014, 19:11
by nimbulan
annisman wrote:How does one actually know that g sync is not 'engaging' in a game. Jw
You can press the menu button on the monitor and it tells you if it's running in normal mode or G-sync mode right on the OSD.
Posted: 02 Mar 2014, 07:33
by hashtonkutcher
I submitted a support ticket on this issue I'll let you know how it goes.
Posted: 02 Mar 2014, 22:12
by annisman
So that will change as you load into a game ?
