XL2546 Strobe Utility
Houd
Post by Houd » 30 Oct 2017, 17:17
Hey.
Tried the strobe utility and I'm not sure I can see the difference. However I toyed around with it and closed the program.
Now when I start it up again it launches default with "Enable" unchecked.
Persistence and Crosstalk Area are at a random set point - not sure it's the same place i left it at.
Do the program hard save the settings I choose once I close the program? And if I want to revert back to default how is that done?
Also when I move the Persistance slider from clearer motion to brighter screen it gets darker. Shouldn't it be the other way around?
metalzone84
Re: XL2546 Strobe Utility
Post by metalzone84 » 02 Nov 2017, 07:47
Houd wrote:Hey.
I have the same problem. Help
Post by Chief Blur Buster » 03 Nov 2017, 13:33
This is a known bug. The scale is reversed compared to other Zowie series.
For Crosstalk, go to http://www.testufo.com/crosstalk. Slide the slider while watching the test. You'll see the double-image ghosting shift upwards/downwards. Position the crosstalk so the center of screen is clearest (where your crosshairs is).
A new version, Version 1.6 will be better for XL2540/XL2546 users.
Keep tuned for Version 1.6
Houd
Post by Houd » 05 Feb 2018, 15:51
Tried to re-test. I don't experience any difference in ghosting when using the sliders in various positions. Only the brightness of the screen changes. Not sure I understand the tool properly.
When does 1.6 arrive?
zigo
Post by zigo » 18 Feb 2018, 10:19
hi i am going to buy the benq 2540 do you recommend it??
Post by Chief Blur Buster » 19 Feb 2018, 15:01
zigo wrote:hi i am going to buy the benq 2540 do you recommend it??
I already replied here and here.
