got XL2740 today, simple review, any questions?
dreamstr1ker
Post by dreamstr1ker » 14 Jan 2018, 21:03
live in china,sorry about my english
got one before officially released, tweaked about and used couple hours
AMA settings
no blur reduction in menu, just in factory menu, like xl2540
ufotest moving maps 1920 pixel/sec barely readable, with longer and more obivus tail than xl2540
xl2740 and xl2540 both with BR on and intensity and area set to 10
will be pleased to test around, so jusk ask
Re: got XL2740 today, simple review, any questions?
Post by Chief Blur Buster » 14 Jan 2018, 22:19
Thats great to know!
I think the XL2540 uses voltage-boosted strobing, so it can achieve brighter at shorter persistence. The DyAc monitors tend to be brighter.
You can lower Strobe Length to make map labels readable at 1920pps or 3000pps, but the screen may go very dim.
Also, please try Strobe Utility at www.blurbusters.com/strobe-utility and let me know if it successfully works with XL2740.
dreamstr1ker
Post by dreamstr1ker » 15 Jan 2018, 02:13
Chief Blur Buster wrote:Thats great to know!
Also, please try Strobe Utility at http://www.blurbusters.com/strobe-utility and let me know if it successfully works with XL2740.
change intensity may just change the brightness, no visible effect on motion clarity to me, could not make the street name more readable
strobe utility is no go,with hdmi 2.0, identified as generic pnp monitor in device manager
lexlazootin
Post by lexlazootin » 15 Jan 2018, 04:03
I'm not quite in the know about Benq, does it just have a newer panel or what?
Falkentyne
Post by Falkentyne » 17 Jan 2018, 01:14
Isn't this the same exact type of "bug" in the XL2540 originally?
This monitor was advertised as supporting ADAPTIVE SYNC and never blur reduction.
And in the original very first firmware, changing INTENSITY only changed the brightness, didn't change the blur reduction at all.
Only in newer firmware, did changing intensity actually change the strobe persistence properly.
Maxe
Post by Maxe » 17 Jan 2018, 06:02
Does the monitor produce any coil whine sort of noise when above 144hz or at 240hz?
Post by Chief Blur Buster » 17 Jan 2018, 13:41
Falkentyne wrote:Isn't this the same exact type of "bug" in the XL2540 originally?
Ever since BenQ Zowie came up with DyAc:
Blur Reduction has been an unofficial feature in many of the non-DyAc BenQ/Zowie monitors. It's there, but it's an unofficial feature whenever DyAc is not advertised.
That said, strobe intensity should be changing pulse width, not pulse height. Otherwise, persistence does not go down. It may be time for me to remind BenQ-Zowie, I'll reach out to my contacts.
dreamstr1ker
Post by dreamstr1ker » 18 Jan 2018, 20:29
Maxe wrote:Does the monitor produce any coil whine sort of noise when above 144hz or at 240hz?
yes. i believe so, I place the monitor next to chassis it's still noticeable while web surfing, while gaming the air-cooling noise kicks in
Maxe
Post by Maxe » 19 Jan 2018, 07:39
dreamstr1ker wrote:yes. i believe so, I place the monitor next to chassis it's still noticeable while web surfing, while gaming the air-cooling noise kicks in
Thank you for checking. Seems to be an issue with the 240hz panels that many don't notice or comment on I suppose.
lexlazootin
Post by lexlazootin » 19 Jan 2018, 08:32
I've got a Acer 240hz 24" G-Sync that doesn't make a sound.
