BenQ XL2430T - 1080p, 1920x1080 144hz
raphinho
Post by raphinho » 27 Jan 2018, 08:18
Hi guys,
i have a BenQ XL2430T. In the Nvidia Settings i can`t choose 1080p, 1920x1080 (native) with 144hz. I use a displayport 1.2 cable.
I can only choose 1920x1080 144hz.
1080p, 1920x1080 (native) - max. 60hz: Image
1920x1080 - 144hz: Image
Does someone know what to do, that i can choose the 144hz with full hd (native) ?
144hz no fullhd.JPG (87.56 KiB) Viewed 2187 times
Re: BenQ XL2430T - 1080p, 1920x1080 144hz
Post by RealNC » 27 Jan 2018, 23:06
These are both the same resolutions. So it doesn't matter. 1920x1080 is 1080p.
However, if it bothers you, you can use CRU to edit your refresh rates:
https://www.monitortests.com/forum/Thre ... tility-CRU
