I have laptop with 75hz G-SYNC screen.
I mostly play Battlefield 1 with my fps is something about 70-100.
I have read much about G-SYNC but almost everything is about 144hz sceens and people who have that screens usually have less than 144fps soo its normal to use G-SYNC and for example V-SYNC on, becouse of the g-sync range working.
BUT what about my situation?
I have only 75hz and my FPSes are most above 75hz screen.
Now i use this configuration:
1. In nvidia control panel: G-SYNC ON, V-SYNC ON
In game: V-SYNC OFF, only FPS Cap by command in user.cfg on 71fps
OR
2. G-SYNC and V SYNC OFF
No FPS Limit
No.1.Stability 71fps, It should be smutter becouse of full G-SYNC work BUT it seems to me It's not, but aiming seems to be better.
No.2. When i jave 70-100fps It seems to be smoother, but aiming seems to be worse (that is input lag?)
I know this forum is one of best about G-SYNC soo im asking you for help, what i should to set up, what is the best choice for me etc.
