xbox one x freesync monitor
ahmedpc03
Hi
i would like to purchase a monitor for my xbox one x , supporting freesync
but iam actually confused about which freesync monitors are going to work with the xbox one x
i am not sure if the xbox one x is supporting freesync 1 or 2
there is nothing mentioned from microsoft or amd
even which hdmi version are support it
some websites said it should be hdmi 2.1, and i can see on youtube someone using xbox one x with lg monitor that supporting only hdmi 2.0
https://www.youtube.com/watch?v=Z4lRHI06aaI
and from some others forums, user tried to used an asus monitor but it doesn't work
for me i dont care about the monitor to be 4k or even hdr, since the xbox one x , some games are supporting 60 fps mode on 1080p.
high fps and low input lag is more important for me
i was thinking to get the lg 27mp59g, since this monitor is ips 1080p , supporting freesync and have a good input lag
but i am not sure if the freesync with this monitor is going to work with my xbox one x
i need your help guys and your suggestions pls.
- RealNC
Re: xbox one x freesync monitor
There are no consoles that support freesync. I think they might add HDMI VRR in a future update to the X? But I don't think this is supported right now.
https://www.windowscentral.com/why-xbox ... ut-hdmi-21
No consoles support FreeSync yet..... unless you are running an emulator on a PC.....and for that, it is mainly lag-reduction without stutter-reduction.ahmedpc03 wrote:high fps and low input lag is more important for me
Also, a monitor cannot improve console framerates.... although a very select few (e.g. older XL2720Z) can reduce console motion blur via single-strobe motion blur reduction - www.blurbusters.com/faq/motionblurreduction
ahmedpc03
hmmmmm
i contacted microsoft xbox support ask them if the xbox one x supporting freesync or not
they confirmed that the xbox one x is supporting freesync monitors, but we need to test this soon
ill let you know guys
thanks
thanks
- RealNC
That's good news.
I have heard that the Xbox One X already has all the hardware necessary to support FreeSync monitors.
Not activated AFAIK though.
I suspect that this feature will be activated in the not-too-distant future. One never knows for sure, though.
Given HDMI 2.1 supports variable refresh rates, this would be a great expansion of FreeSync coverage in the industry, and massively reduce console input lag (since most console games use VSYNC ON).
HDMI 2.1 VRR, VESA Adaptive-Sync, and AMD FreeSync, all uses the same display protocol, and are essentially interoperable with each other -- their protocol venn diagram nearly perfectly overlaps, having been based off each other. AMD even confirmed this to me directly at CES 2018.
- RealNC
Microsoft just announced that they will add freesync support:
http://www.guru3d.com/news-story/freesy ... soles.html
So the person you contacted at Microsoft xbox support who said it supports it already was bullshitting you. So much for "support"
They will also add 1440p support. Which is pretty awesome. Playing on a 1440p freesync monitor should mean high FPS, and it might make me look at consoles again (been avoiding them like the plague.)
open
It's freesync 2 that it will support. Keep in mind that developers will have to patch in support in many cases. It should be easy for most titles to swap to vrr. But consoles have been running vsync games and it is possible that simply switching the refresh mode will create issues with timing, physics, animations, ect... Some time testing and fixing bugs is required. I think it's great that consoles are moving to vrr. It's an amazing way to really use the power efficently and with lower input lag in many cases.
Also this was likely announced to imply that xbox will support the hdmi vrr once the standard has been developed. These companies can't say that they support a standard before it is defined.
Well, semantics.RealNC wrote:Microsoft just announced that they will add freesync support:
The hardware already supports it.
It's the OS / software that doesn't yet support it.
It is my current understanding that the XBox One X and S that people already bought today, already has FreeSync support built into its hardware. It's just not enabled in software yet.
It's also up on the XBox One specs page.
lexebidar
Lg monitors are extremely interesting.
Do You also play on pc? then their 144hz tn monitors are cool to i guess.
If You want it only on ps4 and don't mind ips glow, lg 27mp59g could indeed be a nice option (ot it's 24" version)... I might be wrong because I've not tried this monitor myself but it's one of very few 1080p ips that is above 60hz (75hz) and does single strobing. Wonder if that would be useful on xbox one.
Also - it kinda depends what games You play. Even though tn and ips have the same 1000:1 contrast, I find tn panels a bit better for darker games since ips glow can be disturbing (but not a deal breaker). I guess it's subjective.
But since You have xbox one X, don't You want 4k monitor?
