Hey there ,
To the first thanks for your Great Work !
I have the 2540 and Activate the Strobe Tool is it normal that i must push the Crosstalk Area to 95?
XL2540 Question
Re: XL2540 Question
This is what sometimes happens on the 240 Hz BenQ/Zowies -- screen centre sometimes look best with such large offsets.perling wrote:Hey there ,
The main effect is slightly shifted input-lag gradient effects (since input lag is lowest in the areas immediately above the strobe crosstalk band, and highest in the areas just below the strobe crosstalk band). That said, the refresh cycle of a 240Hz monitor is only 4.2ms and the average strobe lag is only 2ms at 240Hz. At this stage, for many gameplay tactics, the blur reduction advantages can outweigh.
perling
Re: XL2540 Question
Thank you very much for the Answer :=)
