Kind Regards,
yarr
You have to enable/disable it in the Factory Menu.yarr wrote:I recently upgraded to an BenQ XL2540 from a XL2720 and I stumbled upon the strobe utility on this site. It is telling me my monitor is compatible and to enable "Blur Reduction" I have looked everywhere in the monitors menu and for the life of me can not locate the option to enable/disable Blur Reduction. How am I missing it? What am I doing wrong? Out-of-Box the colors are a bit warm and soft for my taste so I went to google to see if I could find some more optimal settings. Anyway, Thank you for taking the time to read my post.
For strobe crosstalk tuning:yarr wrote:Thanks for the quick response! I plan on setting up both monitors once I can find a good mount for my desk, it's always nice to have a second monitor. I will make sure to run the app on that monitor as well.So far, i'm playing with the software whenever I align the aliens middle screen they seem to misaligned somewhere else. I have a feeling this will take a lot of patience or I'm doing it wrong hah!
