So i just bought this cheap 20" benq GC2870H for about USD 180, VA panel...
test it using this https://www.testufo.com/ghosting#backgr ... &pursuit=1
it seems setting the AMA off / High / Premium does not change much, all have trailing black shadow(called ghosting right?) of exact length, only in high / premium there is extra "Corona", the corona is longer in premium.
Tried the service menu and factory menu if there is extra AMA setting, none available.
So the AMA is useless.
I know you get what you pay for, but any ideas to somewhat make the the ghosting better?
about benq GC2870H AMA
Re: about benq GC2870H AMA
Ah well, never mind, it seems the ghosting are reduced to far better level over time, so i guess if you buy VA panel "burn-in"-it first like a speaker/headphone.
May be it's need some time just to warm up?arifinch wrote:Ah well, never mind, it seems the ghosting are reduced to far better level over time, so i guess if you buy VA panel "burn-in"-it first like a speaker/headphone.
- lexlazootin
i've noticed temp effects TN panels as well, When it's cold they are slower and it overshoots when it's warm.
