Being a 1920x1200 model, is it possible to OC this safely up to 72 Hz? Or should I create a custom res. of say standard 1920x1080 and OC? I just need around 72 for gaming, doesn't matter if its at 1080p instead of 1200p.
Anyone OCed the said model?
Overclocking a Dell U2415
haanuman
Re: Overclocking a Dell U2415
I think you can do it!
I searched for your query a bit and found this, I think it will be helpful to you
https://forums.hardwarezone.com.sg/hard ... 93813.html
