Hello,i just upgraded my monitor to XL2144p 144 hz,Specs are Gtx 1060 6gb,ryzen 5 2600x
i made 2 profiles,1 for general use and 1 for gaming
Gaming profile is: 7 sharpness,15 black,temp 100 100 100,blur reduction ON,rest standard.I edited those in FPS1 setting and saved in gamer2 to be able to swap them fast,is there any problem with my settings/that i edited in fps1?
Now regarding strobe utility,the main reason i bought this monitor was that i wanted the gameplay to feel smoother in FPS games
I installed the strobe utility,ran it,and i`m confused about the settings for Persistence and Crosstalk.
At the moment i have Persistence at 12 and crosstalk at 0,but i dont know if they are good settings.
My goal is to get the absolute smoothness while moving/fast turning/shooting/aiming,and if possible,a little blur reduction
So i suppose i want less input lag
Should i keep using Strobe utility in this scenario? and if the answer is yes,what settings for Persistence and Crosstalk should i use for low input lag(=butter smooth gameplay) without sacrificing all blur reduction?
Thank you in advance
XL2144P Competitive strobe settings help
Re: XL2144P Competitive strobe settings help
Blur reduction modes can amplify visibility of microstutter, so you must compensate by being smooth at everything else.
First, fix your mouse microstutters
http://www.blurbusters.com/mouse-guide
- You want mouse turn left/right to be as smooth as keyboard strafe left/right. If it's not, then fix your mouse microstutters first
- Improved mouse. Get a good eSports league mouse, set to 1000Hz
- Improve mousepad. Get an eSports league mousepad
- Clean mouse feet. Dirty mouse feet makes mouseturns much rougher
- Adjust your mouse sensitivity.
If you raise DPI outside of the game, decrease in-game sensitivity (and vice versa). Strobing fluidity sometimes work work better with higher-DPI + low in-game sensitivity -- if you've got a very, very accurate high DPI mouse that stays accurate at high DPI with no acceleration. But this varies a lot between mouse to mouse, on how smooth they feel at low versus high DPI. Competitive players have their ardent favourite sensitivity ratio between DPI and game sensitivity -- different from each other. Your mileage will vary. But generally strobing fluidity tends to work better with accurate-high-DPI mice selection + usage of reasonably high DPI (set about 50% of max; since max is usually too inaccurate) + lowered in-game sensitivity to compensate for high DPI. For example, if your mouse is 6400dpi, try a 3200dpi setting (50% of max). Experiment with different ratios like 25% of max, 40% of max, and 50% of max, to see how fluidity changes during strobed turn left/right. Use mouse profiles so you have low DPI in Windows and high DPI in game, otherwise your mouse pointer is like a rocket in Windows when optimized for smooth strobed turns with low ingame mouse sensitivity settings
Next, tweak your framerate mechanics
- If you plan to use blur reduction, either use
.........(A) overkill framerate (300fps+ in CS:GO) if you prefer VSYNC OFF. Excess framerate compensate a lot for the microstutter of unsynchronized framerates.
.........(B) OR cap framerate to refresh rate. Most common is VSYNC ON but there are other low-lag tricks / RTSS scanline capping trick to move tearlines off edge of screen. Personally, when I play solo player when strobed, I tend to prefer VSYNC ON since that's reliably keeping everything smooth during strobed oepration. But it's bad for lag for competitive gameplay, and requires lots of tricks to get low-latency equivalents of VSYNC ON. At the end of the day, it's just easiest to uncap the framerate or use ultrahigh framerates (300fps+); it will have slightly more microstutter than VSYNC ON but using overkill framerates+VSYNC OFF is still a hell lot less lag and less fiddly for strobed operation.
.........(C) There is an option (C) called the ULMB+GSYNC hack (75Hz-155Hz) but it is not for the faint of heart and only works well on 240Hz GSYNC monitors and has major flicker problems in most games.
Item (A) is far by the easiest.
Fixing microstutter is useful for non-strobed operation, but is super especially important for strobed modes since the clarity of strobing (e.g. ULMB) amplifies microstutter visibility -- motion blur historically masks a lot of microstutter -- and the lack of motion blur makes microstutter hugely visible. That's why a lot of people say "ULMB looks jittery" or "Blur Reduction looks very stuttery" when it doesn't have to be, after sufficient tweaking. Fix that first.
Finally, tweak the subtleties of blur reduction
Now you can focus on fixing the double-image problem. For this, use TestUFO crosstalk test to calibrate blur reduction mode.
Adjusting the position of the crosstalk with Strobe Utility can let you decide what part of the screen you want to have the lowest lag. By using the built-in TestUFO test, you can tell what part of the screen has the worst crosstalk. The lowest lag always occurs in the area right above the crosstalk bar.
--> If optimizing for clearest image, position the "crosstalk bar" offscreen
--> If optimizing for lowest lag at crosshairs, position the "crosstalk bar" just below your crosshairs
These diagrams tell you how you can customize your input lag of your blur reduction mode, based on the location of the crosstalk bar.
Now, if you are prioritizing for zero crosstalk, you definitely want to use a slightly lower Hz (e.g. 120Hz instead of 144Hz) and try the Large Vertical Total tricks on your XL2411P. Your monitor is capable of the VT1502 trick, which is capable of hiding nearly all the strobe crosstalk offscreen (large 422-line blanking interval between 1080p refresh cycles provide plenty of time for LCD pixel transitions complete between refresh cycles).
Rules of Thumb
The lower the Hz, the less crosstalk you will get.
The larger the VT you can get, the less crosstalk you will get.
Then whatever crosstalk you have left, you can adjust the crosstalk bar upwards/downwards.
Adjust "Persistence" to user preference. Look at the dots of the UFO eyes as you adjust. Lower persistence settings will mean clearer motion but darker. For competitive gameplay, you'll want to keep it almost maxed brightness, since brightness is usually more important. But adjust to preference.
Rules of Thumb
