COUNTDOWN: Strobe Utility launched!!
Post by Chief Blur Buster » 16 Mar 2014, 19:34
Blur Busters Strobe Utility app is now available for download!
http://www.blurbusters.com/strobe-utility/
It allows you to turn BENQ Blur Reduction from "worse than LightBoost" into "better than LightBoost".
I've added new ASUS and BENQ menus in the top menubar of Blur Busters.
(Worked a very long weekend, all work and no play.)
waterboy849
Re: COUNTDOWN: Strobe Utility launching midnight ET March 16
Post by waterboy849 » 17 Mar 2014, 02:14
will you be providing a link to where you can buy a BENQ Z-Series monitor with the v2 firmware already pre-installed soon?
Post by Chief Blur Buster » 17 Mar 2014, 03:39
waterboy849 wrote:will you be providing a link to where you can buy a BENQ Z-Series monitor with the v2 firmware already pre-installed soon?
Done: http://www.blurbusters.com/benq/v2-firmware-included/
Image ... Image
Juin
Re: COUNTDOWN: Strobe Utility launched!!
Post by Juin » 17 Mar 2014, 09:38
Will you also provide a link for people in Europe? It looks like for me the BenQ Germany Store does'nt even sell Monitors they all link to various other Stores, just asking if there will be something for people in Germany provided here or do i need to ask every Seller which firmware they have?
Post by Chief Blur Buster » 17 Mar 2014, 10:43
I will find out -- keep tuned. It may be a few days before I gain some information for European users.
cybrnook
Post by cybrnook » 17 Mar 2014, 11:02
Thanks again for this.
Now just waiting for the MSTAR to arrive.
masterotaku
Post by masterotaku » 17 Mar 2014, 17:01
Question: does the motion blur reduction work at less than 60Hz (1 strobe per Hz)?
I know that it would flicker a lot, but it can be interesting for 30fps games, for example :lol: .
Monitor: Asus PG278QR
Post by Chief Blur Buster » 17 Mar 2014, 17:09
masterotaku wrote:Question: does the motion blur reduction work at less than 60Hz (1 strobe per Hz)?
I haven't yet dared to test sub-60Hz situations :|
As it stands, 60Hz strobing is there only as a bonus (e.g. emulator use), even though it feels more flickery than a 50Hz PAL CRT.
EDIT: It strobes all the way down to 50Hz, but I wouldn't recommend it. ;)
Juin
Post by Juin » 24 Mar 2014, 11:34
Chief Blur Buster wrote: I will find out -- keep tuned. It may be a few days before I gain some information for European users.
It has now been a week so wanted to ask again will there be any news for Europeans in the near future?
crun
Post by crun » 25 Mar 2014, 15:13
Is it possible to find out is it V1 from V2 just from the box? Like product code, batch or something
