Hey, I bought an Asus PG27VQ 30days ago. And now I have the problem that it shows blue/red/green/white at startup and can't be overclocked to 165hz -
according to Asus Forum: "the monitor seems to be in factory mode. You can easily get out of this mode by deactivating 2 things in the manufacturer menu/service menu."
And now to the actual problem ... how do I get into this service menu (with which key combination) to switch off Factory Mode and burn in pattern fields?
Video with the problem:
https://drive.google.com/open?id=1t5D5q ... HqA7K00_Ia
Link to Asus:
https://rog.asus.com/forum/showthread.p ... -TO-165-Hz
ASUS PG27VQ change colors, cant overclock bug
Re: ASUS PG27VQ change colors, cant overclock bug
Yeah, this may be one of the factory/debug modes.
Try these tips
Credit:
https://rog.asus.com/forum/showthread.p ... ebug-mode/
This may not be the same on other monitors, but it's worth a try if your monitor is unexpectedly stuck in Factory mode or Debug mode;
Some people needed to RMA when this happened, but let me know if you manage to turn off this mode.
Try these tips
orstep 1:Turn the monitor on
step 2:Press and hold the menu button down
step3:"UNPLUG the Monitor" (keep holding the menu button)
step 4: plug the monitor back in and power on (what I found doesnt specify when to release the menu button so i would just hold it down the whole time until its back on)
step 5: your supposed to be able to navigate the service menu at this point.
Warning: Try at own risk.To turn off debug mode on PG279Q
1. Turn off the monitor
2. Click on Gameplus key twice
3. click the key 5-way button twice
4. next, click exit key on 5 way button twice
5. it will enter factor mode
6. Enter OSD -> System Setup -> All Reset -> Yes
7. Go to Light in Motion -> On
Credit:
A1MSTAR_
doesn't work. i found this at google but every monitor has its own code
if it had been that easy, I wouldn't have asked here. ^^
