Hello, just as the subject says my Benq XL2411Z, when set to a refresh rate higher than 60hz, seems to have a brightness stuttering problem: the screen flashes alternatively from lighter to darker tone. This is only seeable while using a low brightness settings and is as painful for my eyes as (to crudely say it) a needle for my urethra.
I have two screens (the 2nd one being a cheaper (60Hz only) one used only to handle thing while playing). The BenQ XL2411Z is wired via a DVI Dual Link (Considered on the resolution change tab of the Nvidia panel as a DVI only, not sure if it is important)
My specs are the following :
- GeForce GTX 1070
- Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
- 16GB RAM
- Tell me if i forgot something (specswise or not); not used (as you may have seen) to make such demands
Thank you for reading and even more for those who'll be able to help.
Benq 2411Z Brightness Glitch at a >60Hz refresh rate
Gundamoiseau
Re: Benq 2411Z Brightness Glitch at a >60Hz refresh rate
Some older monitors sometimes couldn't keep the monitor voltage stable at dimmer settings -- very rare now. Other times, it's just the monitor getting old (if it started happening recently)
If your monitor brightness is erratically flickering (like a candle) only during low brightness settings, here are workarounds:
(A) Try a higher brightness setting and then instead using NVIDIA Control Panel to digitally reduce brightness (increase backlight backlight and then compensate by reducing graphics brightness, for roughly equal brightness). The contrast ratio may degrade a bit but may solve your issue.
(B) Or putting a dark film (Neutral Density film / cellophane) on the screen and then increasing screen brightness a bit. Basically a dark piece of translucent plastic to dim your brightened screen.
Gundamoiseau
That would be a fast response time. Thank you for that but (mostly because i really hope it isn't hardware related ...) i'll be a needle in the urethra myself (sorry for that) and ask/add some more details :
- I am actually using the monitor inner options (which, if i'm not mistaken is akin to the backlight ?) to lower the brightness of the screen.
- Is, roughly, one year and a half considered old for a this kind of monitor ?
- The flickering isn't constant (it didn't happen since, of course, i started this topic), worsens the higher the refresh rate is (Only happened once at 100Hz and isn't as painful in 120 as in 144Hz) and oftenly starts when a brusque contrast (between clear and dark color) is on the screen (when using vlc to watch a movie (black letterbox limits) or listening to a audio file that will display a light colored album cover.
- And lastly it can be tampered with by resetting the screen "innate" options or switching back and forth the refresh rate. (Or even by turning off the monitor for some time)
Sorry again for clarifying all that only now but since i won't know the answers/or if it is relevant or not by keeping it to myself, i'd rather ask. Thank you for the previous solution, i'll be sure to try them out when it'll come back.
- RealNC
Sounds like a defective monitor to me. If it still has warranty, you could RMA it.
Gundamoiseau
I, sadly, don't think it still does (after more than a year) but hey it, miraculously, seems to be in a lull for now (it must be alive and fearing of getting replaced or something
I guess i'll stay positive and think it is just a bad low voltage managing problem until i find a new job, if anybody has a foolproof diagnosis of/procedure to know what the problem might be, i am still al hears and even more so if it can be definitively fixed (which i am not able to hope for too strongly).
Thank you for the opinions until now.
- RealNC
Hm. Displays usually come with a 2 year warranty here. And the warranty is actually offered by the manufacturer, not the store. Check your receipt.
Gundamoiseau
Well thank you, because i actually have a 3 years warranty
But, as i said, after being an eventual pain for my eyes for more than a week the flickering stopped (for now)... If it comes back within a year or so it'll be a one way trip with a return ticket to the manufacturer.
I suppose it can be a closed case until new evidences are found, thank you again!
Edit : Well it came back!
