LagBuster
Post
by LagBuster » 15 Dec 2018, 11:02
Hey, I just got a new monitor. It isn't the best monitor, but I got it for cheap. I noticed sometimes there are visible artifacts in the form of intermittent horizontal lines (they show up for less than a second). It's connected via HDMI, native monitor timings (2560x1440@60). The problem gets worse and more pronounced if I try to overclock it.
Haven't tried the other video interfaces because I can only use HDMI right now (using the motherboard's iGPU output). Any ideas?
Post
by Chief Blur Buster » 15 Dec 2018, 13:33
Such line artifacts flickering. I'm not sure if this is a panel-related or cable-related but seeing intermittent flickering lines randomly bother me during movies or browsing would be bothersome.
If panel-related, this could be an RMA issue.
You may want to bring another source (laptop with other outputs / adaptors) and a different cable and see what happens, to try to rule out external factors.
LagBuster
Post
by LagBuster » 15 Dec 2018, 14:15
Thanks, Chief. Could this be temperature related in any way? Because as the day progresses I don't notice any artifacts anymore. I've been using the monitor for 2 days and it seems that I only get the artifacts when I turn the monitor on after being turned off for a while.
Post
by Chief Blur Buster » 15 Dec 2018, 14:46
It could be a defect that is hidden by thermal expansion effects, e.g. connectors, cold solder joints, panel ribbon, etc -- one of the many possibilities. This problem is generally not easily diagnosable -- so either requires RMA or living with it.
LagBuster
Post
by LagBuster » 15 Dec 2018, 14:52
Thanks again. I'm okay with it, given that I paid 160€ (inc. taxes and shipping) and it's not too distracting. The price is right for this one, if you ask me.
Post
by RealNC » 15 Dec 2018, 16:33
Keep your warranty handy though. At some point it might get worse, or you might get too annoyed with it.
Steam •
GitHub •
Stack Overflow
Post
by Chief Blur Buster » 15 Dec 2018, 23:04
Agree. Keep the original monitor box and the receipt!
