XL2546 DYAC HELP Please
Gamersdont
Post by Gamersdont » 27 Dec 2018, 23:41
Hello everyone.
Some days ago i bought XL2546 DYAC benq zowie monitor, but i seem to have a problem with Dyac. I dont know how to explain but when i move around fast ingame (csgo) jumping around moveing my mouse left right etc and i can see a shadow following the image..
https://www.blurbusters.com/wp-content/ ... verage.png this is what i mean, when im ingame and i watch something and jumping around when the image or object is moveing i can see this https://www.blurbusters.com/wp-content/ ... verage.png but with dyac off its like this https://www.blurbusters.com/wp-content/ ... k-good.png
a lot of pro players i have talked with say dyac is really nice for csgo and it helps them so i was wondring if my dyac is broken or is there something im missing please to do?
i will test anything you guys recommend me please guys would be very grateful if people could help
Re: XL2546 DYAC HELP Please
Post by RealNC » 28 Dec 2018, 00:28
That's called crosstalk. It's normal in blur reduction mode. Movements become more clear, but there's this slight after-image behind moving objects.
The problem is usually reduced in 144Hz DyAC mode. 240Hz DyAC makes crosstalk more visible.
Gamersdont
Post by Gamersdont » 28 Dec 2018, 10:32
Fak i only bought this screen becauase i kinda play high lvl csgo and everone is useing 240hz so there is no way to fix this? a lot of pro players has never played with blur reduction on other mointor back in the days like 144hz etc but now with dyac people are playing it and no one has said about this problem is it on all dyac monitor or?
longjeang
Post by longjeang » 29 Dec 2018, 02:10
Gamersdont wrote:Fak i only bought this screen becauase i kinda play high lvl csgo and everone is useing 240hz so there is no way to fix this? a lot of pro players has never played with blur reduction on other mointor back in the days like 144hz etc but now with dyac people are playing it and no one has said about this problem is it on all dyac monitor or?
I have xl2546 too, i'm cs go high lv play too. And same with you when i turn on dyac (see a shadow) / off dyac(not see a shadow).So i can say your dyac is completely normal. You should not use the dyac to play CS GO, I feel a little latency when I use it, when I move the mouse I can feel it.
Falkentyne
Post by Falkentyne » 30 Dec 2018, 12:47
Gamersdont wrote:Hello everyone.
Open the "factory menu" (See the sticky).
Find an option called "OD Gain"
then lower the value there.
Make sure AMA is on high before changing this value.
This value will not survive resolution or refresh rate changes (except GPU scaled resolutions).
Gamersdont
Post by Gamersdont » 01 Jan 2019, 22:11
what will this do remove my problem that i did desecribe?
Falkentyne
Post by Falkentyne » 06 Jan 2019, 17:47
Try it and find out. I don't know, as I don't have any of these monitors.
There was feedback in the old XL2540 adaptive sync thread where people messed with this setting and had splendid results with blur reduction AMA inverse ghosting (not boundary strobe crosstalk) witih this setting..
Faustiris
Post by Faustiris » 02 Feb 2022, 19:59
Hello, I just bought the same monitor. Long time ago is your post, but, I souls like to ask you about the crosstalk, did you improve? I also play high LVL cs go.
I also ser some ghosting when I move fast my mouse.
