DIY 240Hz Non-interpolated zero-buffer display.
cirthix
Self-made interface board. DLDVI input to 4ch LVDS.
Tested with gtx 660ti, gtx 580, and hd7970. All worked perfectly after removing pixelclock limit in drivers.
Glitch-free at 240Hz (530MHz pixelclock). LED PWM frequency set to 16KHz. Lightboost and strobing is NOT supported. It has two edids, one only presenting 1080p@240Hz(forces all apps to run at 240Hz all the time, since no other modes are supported), the other offering 120Hz and 60Hz for compatibility's sake (eg: before drivers are patched).
Boards specifically with VG278HE internal connections will be available for sale in mid-january. email for details. cirthix at gmail.com
Other models with 120/144Hz panels may work but might require cabling modifications. I will help you do this if needed.
Side-note: the board can also handle 2560*1600@120Hz, but there were significant panel artifacts (lines and underdriven areas) when testing with lm300wq5-sla1.
Re: DIY 240Hz Non-interpolated zero-buffer display.
Hey,
I have been in touch with you, and I'm glad you are here now!
VERY impressive electronics engineering there -- beating the monitor manufacturers to a true 240Hz LCD capability, direct-driven from a computer. At 1/240sec real-time scanout with no buffering. Even if you use VSYNC ON, you're getting input lag if as little as 4ms maximum with VSYNC ON. That would be the world's lowest VSYNC ON input lag -- for people who hate tearing. And in fact, this would be perfect for future G-SYNC too -- raising the 144fps cap to 240fps.
Thanks for posting here. Your project is "Area 51" league here -- and belongs here, too! I've already blogged about your project at:
http://www.blurbusters.com/true-240hz-l ... s-project/
It's good to see you in these forums. You've done some incredible engineering there.
Feel free to use this thread to followup on this project, especially if you're making new modifications to this!
I would also like display manufacturers to work on true-240Hz LCD's (with good color quality), preferably combined with G-SYNC. Having G-SYNC with a higher framerate cap would be great for uber-competitive players that want to play at faster than 144fps!
- Ahigh
Q83Ia7ta
By the way: input of 144hz is bandwidth limit of DL-DVI or lcd panels?
- Ahigh
Sign me up as your first customer. I have a VG278HE here ready and waiting!!!
- shadman
Assuming you mean 1080p, then it is not a DVI limitation but part of the monitor. I'm not 100% sure which part though.Q83Ia7ta wrote:By the way: input of 144hz is bandwidth limit of DL-DVI or lcd panels?
Haste
Very nice work cirthix!
Congrats on making the first true 240Hz LCD happen.
Monitor: Gigabyte M27Q X
Q83Ia7ta
Yeah i was thinking about 1920x1080@144hz. If you sure it's not limit of DL-DVI standard then it's some part main board. I don't get why all new gaming monitors from benq, asus, iiyama, viewsonic, aoc, phillips, etc are using this 144hz limit. Even first and new cheap chinese monitor HKC X1 uses 144hz.shadman wrote:Assuming you mean 1080p, then it is not a DVI limitation but part of the monitor. I'm not 100% sure which part though.Q83Ia7ta wrote:By the way: input of 144hz is bandwidth limit of DL-DVI or lcd panels?
DL-DVI is overclockable to dotclocks necessary for 2560x1440p 120Hz, which is roughly equivalent in dotclock to 1920x1080 240Hz. So, 1080p 240hz isn't part of DL-DVI spec, but it's overclockable to get there.Q83Ia7ta wrote:shadman wrote:Assuming you mean 1080p, then it is not a DVI limitation but part of the monitor.Q83Ia7ta wrote:By the way: input of 144hz is bandwidth limit of DL-DVI or lcd panels?
Also, two DisplayPort channels also has enough bandwidth to output 1080p 240Hz.
Also, refreshing this panel 240 cycles per second, will have some color degradation, so keep this in mind. Input lag will be ultra-low on this panel, since this is a zero buffered LCD, with only a ~4ms difference between top edge of screen and bottom edge of screen. (unlike ~8ms difference between top/bottom for 120Hz scanout, and ~16ms difference between top/bottom for 60Hz scanout).
I am really looking forward to seeing what non-strobed 240Hz looks like. Being an estimated 1/240sec = 4.1ms sample-and-hold, I expect it's roughly somewhere between 144Hz non-strobed (6.9ms) and LightBoost=100% (2.4ms) in motion clarity.
Akoni
wow!
you my friend, are awesome
engineering skills to the max. do you have any other information on the upgrade?
