g-sync + ULMB
Kaggewas
g-sync + ULMB
Post by Kaggewas » 04 Jan 2019, 05:19
I have ULMB technology, what is it for? Many people use g-sync + ulmb, is it better than just g-sync?
Re: g-sync + ULMB
Post by RealNC » 04 Jan 2019, 06:59
Re: g-sync + ULMB
Post by Chief Blur Buster » 04 Jan 2019, 21:44
Yes, look at http://www.testufo.com and then turn on ULMB. You'll see the motion blur disappear.
For some, it is amazing to see CRT-clarity motion, when you see it for the first time. One con is the harsh multi-image artifacts of framerates lower than Hz, so you really need extremely good stutter control -- and synchronized framerate matching refresh rate -- to make ULMB look good in games. It's wonderful for scrolly games like RTS but less good for people who only stare at crosshairs in CS:GO. Benefits of ULMB is game-dependant.
cacs1985
Re: g-sync + ULMB
Post by cacs1985 » 09 Jan 2019, 07:55
Will the ULMB works with an AMD graphic card?
Re: g-sync + ULMB
Post by RealNC » 09 Jan 2019, 08:07
cacs1985 wrote:Will the ULMB works with an AMD graphic card?
No. ULMB is implemented in the g-sync module and it will refuse to work on non-nvidia GPUs.
(At least that's what people who tried have reported. I don't have an AMD card to test this myself.)
cacs1985
Re: g-sync + ULMB
Post by cacs1985 » 09 Jan 2019, 08:13
Maybe this is wrong place to ask, but does blur reduction feature from Freesinc monitor work nvidia graphic card ?
Re: g-sync + ULMB
Post by RealNC » 09 Jan 2019, 08:17
cacs1985 wrote:Maybe this is wrong place to ask, but does blur reduction feature from Freesinc monitor work nvidia graphic card ?
Yes. Freesync monitors that have a blur reduction function will work with any GPU.
cacs1985
Re: g-sync + ULMB
Post by cacs1985 » 09 Jan 2019, 08:21
TYVM ,sir!
