smoothness in games
Kaggewas
smoothness in games
Post by Kaggewas » 17 Jan 2019, 14:51
Hello everyone, I want to get the maximum smoothness in games, which is only possible, tell me what is needed for this?
Re: smoothness in games
Post by RealNC » 17 Jan 2019, 15:36
If you have frame pacing smoothness issues, you can always try to use RTSS with a frame cap. This usually fixes smoothness issues in games. I use it all the time :-)
Post by Chief Blur Buster » 17 Jan 2019, 16:59
If priority is motion fluidity, you want framerates matching Hz.
- Powerful GPU to keep frame rate matching refresh rate
- VSYNC ON with various low-lag VSYNC ON tricks
- Frame rate cap
If you want more flexibility with varying framerates -- then you want variable refresh monitor such as a FreeSync or GSYNC monitor, see Demo of variable refresh rates which can eliminate stutters of varying frame rates. On such a monitor, the refresh rate stays in sync with frame rate, which makes it much more seamless.
Post by RealNC » 17 Jan 2019, 17:40
Judging from the OP's other posts, g-sync is in use, so there's no need to care about FPS matching refresh rate.
