Strobe Crosstalk XL2546
Rom138
Post by Rom138 » 20 Feb 2019, 09:52
Hello,
I have try to adjust manually Strobe Crosstalk at 182Hz on my XL2546.
how explain here --> https://www.blurbusters.com/faq/advance ... stalk-faq/
I play essentially Fortnite and my resolution is 1680 x 1050. I try to put the Large Vertical Total at 1584 in a custom resolution in Nividia control Panel. But when I start to play Fortnite the resolution change to the default 1680 x 1050 in Nvidia. I don't know why ? is it 1584 to much for my current resolution ?
I try this too --> viewtopic.php?f=13&t=3604 is it better than the the Large Vertical Total tweak ?
Perhaps some people have the best settings for the XL2546 in a game like Fortnite ?
thanks you.
Have a good day.
Re: Strobe Crosstalk XL2546
Post by Chief Blur Buster » 20 Feb 2019, 18:39
Combining odd resolutions with Large Vertical Totals are extremely unreliable with NVIDIA Control Panel. Try using ToastyX CRU and see if it works better.
I cannot really gurantee that Large Vertical Totals work reliably with non-native resolutions. It's very monitor-specific how well they behave with that.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Rom138
Post by Rom138 » 21 Feb 2019, 15:16
Hello,
thanks for your answer. It's work know. I have to check "override scaling mode set by games and programs". But I don't know if it's really work with stretch resolution.
Is this "override scaling mode set by games and programs" had input lag or not ? Not every people have the same answer about this.
ne0x
Post by ne0x » 28 Mar 2019, 18:32
Rom138 wrote:Hello,
thanks you.
Have a good day.
try this:
Press Windows key + R and then type " %appdata% " into the box
Next goto the Local folder and then locate FortniteGame
Then >Saved > Config > WindowsClient > GameUserSettings.ini
Find ResolutionSizeX+Y & LastUserConfirmedResolutionX+Y
enter your resolution there and save the file. now right click on the file and open properties.
check "read only".
Then in nvidia settings check "override scaling mode set by games and programs" setting and make sure it is on fullscreen.
launch the game. see if it works. (keep in mind, because you made the file read only, any settings you change in game after that will not be saved.) Good luck
