colour banding,
Posted: 31 Mar 2014, 22:33
by dippadui
is there any way to reduce colour banding? (xl2411z) video gard is gtx 660, i use settings providet from ---> http://pcmonitors.info/reviews/benq-xl2420z
it have the same panel than 11z. i use 144hz icc...yes i know every panel is unique.
thanks.
Re: colour banding,
Posted: 31 Mar 2014, 23:08
by spacediver
do you see banding without using the icc file?
Re: colour banding,
Posted: 01 Apr 2014, 08:22
by dippadui
yes almost same i have tested different icc profiles.
Re: colour banding,
Posted: 01 Apr 2014, 10:33
by dippadui
these are bf4
Re: colour banding,
Posted: 01 Apr 2014, 12:40
by spacediver
posting screenshots won't help. If the banding is an issue with your display or your video settings, it will only show up on your display. How severe is the banding?
Re: colour banding,
Posted: 01 Apr 2014, 13:34
by dippadui
spacediver wrote:posting screenshots won't help. If the banding is an issue with your display or your video settings, it will only show up on your display. How severe is the banding?
well,its there but not very much, just thinking can it be fixed or reduced.
Re: colour banding,
Posted: 01 Apr 2014, 14:02
by masterotaku
I have the same monitor as you. Banding is normal in this type of panels, as they are 6bit + FRC (dithering). Another issue could be in the game itself. The sky is something prone to banding in games, and some compressed textures can have it, or even the lighting system itself (I think).
There's nothing you can do about the monitor (provided that your gamma and contrast are OK). If the monitor says "I'll represent this shade of color by dithering", nothing can be done.
Re: colour banding,
Posted: 01 Apr 2014, 14:17
by dippadui
ok thats fair enouch,thanks ;)
