DVI-D to VGA Active Adapter
I have 10 series GPU that doesn't output an analog signal. I have to use my CRT using DVI-D to VGA Active Adapter it was expensive startech adapter with mini USB for additional power. It's used on LaCie Electron 19 Blue IV 120Hz. I feel a slight lag using the adapter not sure what to do, i'm considering buying a 900 series GPU. Have others here used Active adapters what's your take on them?
Re: DVI-D to VGA Active Adapter
Active adaptors can add lag.
Lagless adaptors are extremely hard to find -- the HDFury is one of the best in this department and is popular with emulator users. You could do a dumb adaptoring of DVI-D to HDMI, and use one of the better HDMI-to-VGA adaptors that accomplishes it with subframe latency.
Watched a few YouTube videos showing Latency on adapters are 23ms and above. I have purchased a 900 series Nvidia GPU.
Good move.bbluster wrote:Watched a few YouTube videos showing Latency on adapters are 23ms and above. I have purchased a 900 series Nvidia GPU.
The best adaptors to use are the ones that emulation groups are the most picky about. Some of them have found darn nearly lagless HDMI-to-VGA conversion that uses a realtime rolling-window for subframe latency. Reserach the emulation groups to find out how lagless they got HDMI-to-analog conversion to become.
Installed Asus Strix GTX970 using DVI-A to VGA adapter and i'll have to say the difference is day and night over the converter.
CSGO feels tight now. The Converter was a curse!
