Specs look promising, 240hz, .5ms, FreeSync@48-240hz (is there even a reason to get gsync anymore?), low framerate compensation, latency reduction, and for those that care blue light reduction.
Basically everything I'm looking for. However it seems like specs don't tell anywhere close to the whole story anymore (RIP VG248QE). Anyone have reviews or ideas how it's going to perform? Anyone know of a website that's going to be reviewing it? They also have a 27" model, but meh.
Never used AOC and haven't really heard anything about them. It's priced really nicely though all things considered at $330.
AOC Agon AG251FZ2
Re: AOC Agon AG251FZ2
I suspect is the same old story.. they advertise 0,5ms but then after the tests it is same or worse than the 1ms models, like the Gigabyte model for example, wich is 0,5ms and had worse overdrive than the old 240hz. Better wait for reviews!
It mentions MPRT for the .5ms so I was thinking it's a gamed panel. It's tough to tell how many of these are using the new .5ms panels or just rebranding old stuff as well. Glad marketing buzz has reached this level.
does it have some sort of blurreduction ?
