AW2518H or XG258Q or XG248Q for 240hz
Posted: 05 Jul 2019, 03:06
As you can question above, which one should I choose between all of them ? I want the lowest input lag/response rate as much as possible. I only play FPS games all the times. but some game may struggle I know so that's why I put AW2518H with G-sync in there just in case. (Apex Legends, EFT, CSGO, some other fast peace game)
I also did some reasearch myself and saw XG248q has really bad coating but ELMB can do up to 240hz but add some/lot of input lag at a cost. For XG258Q, it has almost the same input lag as XG248 but has better color than XG248. as for AW2518H, I really know much about it... so I like to know more info about it if you own one!! if possible, can I get a graph for input lag/response rate with all 3 monitors ? thanks!!!
Price in my country.
AW2518H (579$)
XG258Q (485$)
XG248Q (419$)
noted: PG258Q is not available in my country.
System that I will this monitor with:
Ryzen 3900x (soon)
Asus RTX 2080TI OC (soon)
AW2518H (579$)
XG258Q (485$)
XG248Q (419$)
Ryzen 3900x (soon)
