higher input lag since switching to zen 2 (high speed test)
ko4
Post by ko4 » 24 Aug 2019, 02:07
specs
ryzen 5 3600
aorus x570 elite
gtx 1060 6gb
dell s2716dg
all fps games felt floaty after upgrading my mobo and cpu so I decided to test it.
I used my note 9 which can do 960fps for 200ms.
results:
map: Training_aim_csgo
fps_max 300
resolution: 1440p native
gpu usage around 30%
all settings lowest
raw input on
multicore rendering off
I should be getting around 9-12 ms according to other user's test but mine spikes up to well over 20ms
I sold my old motherboard but I still have my old intel cpu
however if these numbers do not prove to be normal i can buy a cheap mobo for testing purposes and return it later
boxszs
Re: higher input lag since switching to zen 2 (high speed te
Post by boxszs » 26 Aug 2019, 10:25
Ugh I wanted to buy a Ryzen 5 3600 but now I'm torn..
Why do you have Multicore Rendering off? That is just going to give you lower frames. That needs to be enabled. At least on Intel.
Kheri
Post by Kheri » 26 Aug 2019, 14:05
I'm curious to hear more about your process. Do you have an LED hooked up to your mouse or something?
Interesting stuff.
boxszs
Post by boxszs » 26 Aug 2019, 15:40
Definitely try another motherboard if you are willing to return it just to see if it could be an issue. Try a B450, something relatively cheap like the ASUS STRIX B450-F Gaming.
ko4
Post by ko4 » 28 Aug 2019, 00:08
boxszs wrote:Definitely try another motherboard if you are willing to return it just to see if it could be an issue. Try a B450, something relatively cheap like the ASUS STRIX B450-F Gaming.
I tested mouse movement with a hammer and I got around 9-13 ms so it might be placebo
im still gonna buy a cheap lga1151 mobo next month for testing
B1GGS
Post by B1GGS » 03 Sep 2019, 00:41
Hey what ram speed where you running for zen 1 and now zen 2. showed my buddie this post and brought that up. Assuming they are both using the same speed while zen2 asks for 3600Mhz. interested in seeing this test with a spectrum in ram speed.
ko4
Post by ko4 » 03 Sep 2019, 22:04
B1GGS wrote:Hey what ram speed where you running for zen 1 and now zen 2. showed my buddie this post and brought that up. Assuming they are both using the same speed while zen2 asks for 3600Mhz. interested in seeing this test with a spectrum in ram speed.
My previous rig was an intel one
I am using 3000mhz now with zen 2
senny22
Post by senny22 » 04 Sep 2019, 08:50
Unless you have a really cheap kit then I think you should be able to go higher. My 3200 kit is running at 3800mhz and decent timings.
ko4
Post by ko4 » 05 Sep 2019, 01:27
I am using micron e-die
I will try ocing it again soon but last time i tried i couldn't go over 2400
ko4
Post by ko4 » 11 Sep 2019, 22:37
found another user with the exact same problem.
https://www.reddit.com/r/AMDHelp/commen ... ?context=3
Bought a cheap b150 board to test with my old cpu. Should arrive next week
