- BTRY B 529th FA BN
Re: Bought the HP Omen X 25f
What are you actually asking? How to set up NCP?
There's no official statement about the panel used. Some rumours say it is the latest and some decline that. I went with Acer xn253qx because there was a review.
You might as well use G-Sync with it since it has no drawback on input lag.
Nvidia Control Panel.BTRY B 529th FA BN wrote:I'm curious if I need to register the monitor. If anything needs adjustments. What's NCP?TTT wrote:What are you actually asking? How to set up NCP?
Just figure out the colour settings you like, the Lagom.NL pages are pretty helpful for self calibration.
Try out Gsync, on a 240hz you can't see screen tearing anyway but Gsync adds a different smooth feeling and makes the motion different.
Its just under nvidia control panel, gsync tick box.BTRY B 529th FA BN wrote:How do I do Gsync on this monitor? Thought it was Freesync supported but Gsync unofficially supportedTTT wrote:Nvidia Control Panel.BTRY B 529th FA BN wrote:I'm curious if I need to register the monitor. If anything needs adjustments. What's NCP?TTT wrote:What are you actually asking? How to set up NCP?
