List of monitors that do 1440p@120Hz on XB1X?
All newer XBOX consoles supports 120Hz+ & FreeSync. Getting help with getting "Better Than 60Hz" on the XBOX ONE, XBOX Series S, and XBOX Series X, as well as the PlayStation 5.
suprsoldier
Post by suprsoldier » 04 Nov 2019, 10:23
Does one exist?
TTT
Re: List of monitors that do 1440p@120Hz on XB1X?
Post by TTT » 28 May 2020, 09:27
No and doubt it could run that anyway.
Post by Chief Blur Buster » 28 May 2020, 14:44
See www.blurbusters.com/freesync/list and check the 1440p section.
They still can do both 1440p 60fps and 1080p 120fps.
merleau79
Post by merleau79 » 10 Jul 2020, 00:37
28 May 2020, 14:44
Hi Chief. Would you be able to look at this post that I made about the LG 27gl650 monitor? I just purchased it, but after looking at this site I'm not sure if it is the best for my purposes--mainly input lag and motion blur on both PS4 slim and Xbox One S. While also considering upgrading to the new Xbox in a new or so. Thanks.
viewtopic.php?f=21&t=7216
lajkazir
Post by lajkazir » 15 Sep 2020, 14:26
acer XG270HU Can do 1440p, 120hz and freesync
calvinmiller
Post by calvinmiller » 14 Feb 2021, 14:33
I found good recommendations here, thanks!
