hello i have little issue on my monitor it start ghosting when moving objects i test it on game called overwatch i never had this issue 4-5 months the text on game start blurry when i move right and left the object to i would like to know if its overdrive voltage problem i never overclocked my monitor here video of the issue i try with vsync on to but problem the same
ghosting problem xg258
karavanasam
Re: ghosting problem xg258
If you are asking for help,then why make the video private,genius?
yep sorry my bad the video didnt work for u when its private?karavanasam wrote:If you are asking for help,then why make the video private,genius?
nvm its happen on all my monitors topic can close its ow problem
singleDADAN
pox02, can u tell me what monitor settings do u use ?pox02 wrote:nvm its happen on all my monitors topic can close its ow problem
