Wait for GSYNC or buy a monitor now?
Knxwledge
Post by Knxwledge » 17 Apr 2014, 21:56
Im currently in need of a better monitor because my motion sickness is getting bad the past year.
Im currently looking at the XL2420Z and I know that the BenQ's Gsync offering was suppose to be available soon.
Is GSYNC really that better if you can keep 90+ FPS?
Re: Wait for GSYNC or buy a monitor now?
Post by Chief Blur Buster » 17 Apr 2014, 23:14
Actually, GSYNC dramatically makes lower/stuttery framerates look so much better, e.g. It has more visible effect in smoothing 40-70fps. It will smooth all frame rates, including 90fps+, but has a particularly more dramatic effect on the lower/stuttery frame rates.
Motion blur reducing Strobe backlights (LightBoost, ULMB, Turbo240, BENQ Blur Reduction) have a more dramatic effect on high/consistent frame rates.
GSYNC: benefits low/stuttery framerates more dramatically
Strobing: benefits high/consistent framerates more dramatically
Knxwledge
Post by Knxwledge » 18 Apr 2014, 04:13
Thanks for the reply. I decided to pick up a XL2420Z and I am lovin it so far.
How do I enable Saturation on this monitor? The option is greyed out.
And is 100hz better than 120hz?
