Any way to reduce brightness past 0?
I've set my brightness to 0 and reduced all my color levels to reduce brightness but it's still quite bright. Any way to reduce brightness on my monitor?
Falkentyne
Re: Any way to reduce brightness past 0?
Would help if you told us what monitor you have.
This has been a consternation with some of readers.
There are multiple methods to go below 0
1. Buy a neutral density filter from Amazon or eBay and put it on your monitor.
Here's an example of an ND sheet big enough to cover a 24" gaming monitor to reduce brightness by approximately 0.3 F-stop. There are also other filters (the large rectangle sheets, not the circular filters) if you need much more darkening.
or
2. Use NVIDIA Control Panel to reduce brightness further. (This will decrease contrast ratio though, because brights are digitally dimmed). Make sure Lagom contrast pattern isn't compromised when you do (may need to adjust both Brightness and Contrast sliders simultaneously until things look as good as possible) -- www.lagom.nl/lcd-test/contrast.php
or
I have the Acer Nitro XF252QX, I should note that I have this problem on one of my other monitors as well and that's a VA panel.
Thanks alot! I have an AMD gpu but guess that the situation in 2. is the same. I've tried playing with brightness and contrast and it removes the first 3 darkest boxes but I guess that's the tradeoff.Chief Blur Buster wrote: ↑17 Mar 2020, 15:45This has been a consternation with some of readers.
or
Edit: I figured it out. If I only reduce contrast in the AMD panel, I can still see all boxes in the LCD lagom site. I'm pleased with this for now as it's my TN monitor that's to bright and I'm not overly concerned with the color performance on that panel either.
I have the same problem too with the XF252QX. I thought it was the missing bluelight filter option. Using brightness 10 as mentioned in the tftcentral review my eyes hurt very much after a 2 hour gaming session.
Yeah, I put my brightness to 0 and lowered to contrast in the AMD panel to around 30 which is at a comfortable level for me now.
