So im playing arround with Gsync on escape from tarkov.
I have set the recommended "best" Gsync settings in general for tarkov but i have a small issue.
General Gsync recommended settings suggest to cap your FPS either ingame or outside (RTSS or Nvidia Fps limiter) to 3 fps lower than your maximum refresh rate. In my 144hz monitor that would be 141 fps.
The problem i have is that Tarkov has a native FPS limit of 120 ingame.
There is a work arround for this limit, in wich you Disable Nvidia´s Vsync and enable Vsync ingame. This is a bug, but it "unlocks" your fps, and you can go beyond 120 fps limit.
I have a RTX 2070 Super. With fps unlocked i can hit over 144+ fps on "factory" the most basic and less demanding tarkov map.
So here i have some questions. Since the "recommended Gsync settings" state that you should have your fps running as close as your refresh rate (in my case 141), how detrimental to my input lag / microstutters is the fact that the game is limiting itself already to 120 fps?
What will the result of Running Gsync on + Vsync Off (nvidia control panel) + Vsync ON (ingame) to unlock fps completely but locking fps cap to 141 with RTSS?
Is this a decent work arround for the lame maximum fps limiter the game has?
Escape from Tarkov "Best" Gsync Setup
- jorimt
Re: Escape from Tarkov "Best" Gsync Setup
A minimum of 3 FPS below your refresh rate, it doesn't have to be that exact number. It's merely to keep the framerate within G-SYNC range at all times if your system can otherwise exceed it.
That's perfectly fine, as at 144Hz, you're now 24 FPS within the G-SYNC range. No further limiting needed.
With G-SYNC, none at all. It was built for variable framerates within the refresh rate.Hungerr wrote: ↑27 Apr 2020, 07:38So here i have some questions. Since the "recommended Gsync settings" state that you should have your fps running as close as your refresh rate (in my case 141), how detrimental to my input lag / microstutters is the fact that the game is limiting itself already to 120 fps?
Possibly steadier frametime, but in turn, possibly higher input lag (up to 1 frame) over the in-game limiter. Either that scenario or G-SYNC + NVCP V-SYNC + in-game FPS limit is fine though.
Hungerr
Thanks for your Quick response. I guess i will try both scenarios and see what "feels better".jorimt wrote: ↑27 Apr 2020, 07:50A minimum of 3 FPS below your refresh rate, it doesn't have to be that exact number. It's merely to keep the framerate within G-SYNC range at all times if your system can otherwise exceed it.
