XL2411Z - Should I OC to 200Hz or use blurbuster + 1502VT trick?
trep
Post by trep » 01 May 2020, 16:40
Which is considered best for Valorant?
Re: XL2411Z - Should I OC to 200Hz or use blurbuster + 1502VT trick?
Post by Chief Blur Buster » 01 May 2020, 20:18
About "XL2411Z - Should I OC to 200Hz or use blurbuster + 1502VT trick?" --
If you're not using motion blur reduction, try the overclock:
viewtopic.php?f=8&t=5544
If you're using motion blur reduction, the VT1502 technique may be preferable.
trep
Post by trep » 02 May 2020, 08:40
Hey chief, to answer your question I am asking for the 2 options to be compared:
1- using blur reduction + VT1502 trick @120hz
2 - no blur reduction + 200hz overclock
I'd like to know the consensus on which is better for FPS games, and why.
