How much do ram timings affect input lag?
deama
Post by deama » 21 Jun 2020, 05:24
So let's say I had 16GBs with 14-14-14-28 timings. Let's say there was a precise way to measure input lag and I measured total input lag at 50ms.
If I got another ram set, but this time the timings were at 12-12-12-24, how much would the total input lag reduce by? 5ms? 1ms?
Forum Moderator Team wrote:Moderator Note DISCLAIMER: This Thread Topic Tends To Cover Mostly Wild Goose Chases After Red Herrings. Be Wary of Misinformation / Placebo Effects.
More information about what's real; and what's not real -- explains why we keep these threads open
pwn
Re: How much do ram timings affect input lag?
Post by pwn » 21 Jun 2020, 07:24
memory latency is measured in ns .. Draw your own conclusions ..
I think it will be impossible to notice the difference between 70 and 50ns ..
deama
Post by deama » 21 Jun 2020, 08:37
pwn wrote: ↑
21 Jun 2020, 07:24
From the "ryzen has higher input lag" I got the conclusion that tighter timings of ram could noticeably improve input lag.
Sparky
Post by Sparky » 21 Jun 2020, 09:07
only so far as it has an impact on framerate. So, negligible.
MaxTendency
Post by MaxTendency » 22 Jun 2020, 02:02
pwn wrote: ↑
21 Jun 2020, 07:24
I've been lurking for a bit and saw someone mention that tCL, tFAW and tRFC has huge impact on mouse input. I had no experience with ram overclocking but decided to give it a go. Unfortunately turns out the ram sticks I bought were pretty bad quality so I couldn't boot with lower tCL and tRFC , however I was able to go from 28 tFAW to 16.
And the improvement was really really noticeable. I also got my brother to load in stock profile vs oc profile without my knowledge and I could INSTANTLY tell which one was tFAW 16 because it felt so much snappier. I also tweaked a bunch of other timings but honestly felt no difference. As I said, I couldnt lower my tCL and tRFC so I dont know about them.
Anyways as for latency my adia score went from 75.8ns to 73.7ns after all the tuning. But once again the difference in terms of mouse input was massive.
Ram Before and After.png (71.69 KiB) Viewed 29145 times
schizobeyondpills
Post by schizobeyondpills » 22 Jun 2020, 02:18
pwn wrote: ↑
21 Jun 2020, 07:24
And as said before, CPU core works at 5GHz(5 billion hertz a second) so, thats a clock cycle of 0.2ns 1/5000000000, if it takes ~ 50-70ns for your CPU to fetch data from RAM for every single read or write it does to memory, compare it to 1 cpu clock cycle, 100 times longer. All modern CPUs have 3 levels of caching to reduce that latency, surely theres a reason billion dollar companies on both sides focus so much on this latency to put 3 levels of reduction on all of their CPUs. And not to mention those caches are very small which means more than 90% of memory usage still is done from RAM. Oh, i forgot to say you have 8 of those cores, so 5Ghz * 8 all doing reads and writes from RAM.
Somehow people interested in input lag fail to realize that they use a system which doesnt run in their mind so their perception of nanoseconds/microseconds/milliseconds is irrelevant, yet its the most common flawed argument, to say such small numbers dont matter because they compare it against their perception of time. Once u scale the time to human perspective from CPU perspective it ends up being minutes, months and years.
Also, your CPU does millions of reads and writes a second, so multiply that latency by same amount and now you see why it matters so much.
Me and others posted more in viewtopic.php?f=10&t=7033#p52618 worth reading!
deama wrote: ↑
21 Jun 2020, 05:24
It depends, theres more timings than those 4, like 100+ more, there also some other things a lot of motherboard BIOS developers hide, such as RAM power down mode which adds 5-7ns to RAM latency, and there's also things like tRFC, tCR (Command rate- set it to 1, almost all RAM runs at 2 for bandwidth, not latency), tREFI(refresh interval - increase as much as u can) and many more.
RAM latency affects everything, every single memory operation your OS does, everything your game does, everything your devices do with RAM, so it affects input, ofc.
However tuning ram latency wont do much if you have bottlenecks in your latency pipeline. It doesnt matter if you run to the bus stop or walk to it if bus arrives in 3 hours (say CPU low clock\bloated OS, instead of 5GHz constant + cleaned OS)
Latency reduction of RAM scales with its command rate, power down mode and most important factor being which CPU you have, on AMD you cant be helped much, on Intel its a different story, 5GHz + low latency ram scales far better than 4.5GHz or 4.8GHz. Higher CPU clock on intel + lower RAM latency help eachother out in terms of responsivness/smoothness.
However by my testing i'd say on 4.8GHz+ Intel CPU(constant clocks, tuned bios, no C states or downclocking) 1ns of RAM latency is worth ~ 30-100 FPS of input lag reduction, thats total, meaning both in terms of responsivness/smoothness and actual pipeline latency reduction
Sparky wrote: ↑
21 Jun 2020, 09:07
Wrong, read above. Even if your framerate stays the same, RAM latency is the most impactful thing in entire PC after CPU clock/ucore speed that affects input lag, yet so many ignore it. To put this in simple perspective, RAM latency is equivalent of time it takes for you to remember something.
Also anyone reading this in the future, adjusting your timings wont do much in terms of responsivness if you dont disable RAM power saving/DRAM power down mode which causes it to be turned on and off to save power and adds huge latency penalty.
Not to mention most RAM overclocking is done for higher clocks and bandwidth, while optimizing for latency is opposite of bandwidth, so you need to aim for lowest RAM latency, use this calculator https://notkyon.moe/ram-latency.htm
Sparky
Post by Sparky » 22 Jun 2020, 04:50
Any latency from main memory reads and writes directly impacts how fast the main loop of the game engine runs. So if your CPU is the bottleneck, it shows up as a decrease in framerate. If your bottleneck is the GPU, it doesn't show up at all. The only way it could show up without impacting framerate is if your bottleneck is a well implemented in-game framerate limiter, which is blocking the game engine before it collects user input, and after it sends a frame to the GPU. Even then, the latency induced is some portion of one frame of latency, at whatever the current framerate is.
This makes no sense whatsoever. A difference of 100fps could be worth 25ms of latency, or it could be worth 0.4ms of latency. It's completely meaningless without knowing where you're starting from. Have you actually measured how much difference in button to photons latency there is? What games have you tested, and how does their cache hit ratio impact the difference in overall latency?
deama
Post by deama » 22 Jun 2020, 07:40
MaxTendency wrote: ↑
22 Jun 2020, 02:02
What do you mean snappier? As in, the mouse movement felt less laggy, or did the mouse clicks feel less laggy? Did you also try out the differences on the keyboard?
Also, what ram sticks did you use?
schizobeyondpills
Post by schizobeyondpills » 22 Jun 2020, 10:16
Sparky wrote: ↑
22 Jun 2020, 04:50
It impacts entire OS not just the main loop of game engine. This has nothing to do with a bottleneck, it reduces latency of two most primitive PC operations being memory write and read which results in huge scaled benefits.
Its not a raw 100FPS from 0 to be able to divide into MS directly, reducing ram latency gain can be compared to 30-100 FPS gains beyond stable 144+FPS, depending on multiple factors like Intel/AMD/Core clock/ucore clock/ram command rate/how low ram latency is (< 35ns - it scales exponentionally, not lineral),
deama
Post by deama » 22 Jun 2020, 14:17
Alright so I just overclocked my tFAW timings from 39 to 16, I can't really feel a difference on mouse movements or really anything much.
Is there some sort of general guide on what each of the timings does, or is it basically the wild west?
