Or high input lag is limiting hz to 60?
Sorry for my bad english
Correct, only at 60Hz; 280Hz VRR at ~60 FPS won't have it.
PixelDuck87 is right, I guess? He asked a specific question and received this answer from RTINGS, so seems like even when using G-SYNC Compatible/FreeSync this monitor has extreme input lag issue, getting progressively worse the lower fps/refresh rate goes.
Their wording isn't clear enough to determine what they meant.
I have second thoughts about it, too, but the way the question is asked strongly suggest that their answer refers to maximum refresh rate (280 Hz) and 60 fps when VRR is enabled (thus 60 Hz), because PixelDuck87 specifically asked about it. They actually corrected him, as they measured even higher input lag with VRR at 60 Hz, saying that "as the frame rate drops, the input lag increases."jorimt wrote: ↑27 Jul 2020, 09:46Their wording isn't clear enough to determine what they meant.
When they say "At 60Hz with VRR, we measured 40.4ms of input lag," do they mean the max physical refresh rate set to 60Hz in the NVCP w/G-SYNC enabled with a 60 or higher framerate, or do they mean the max physical refresh rate set to 280Hz in the NVCP w/G-SYNC enabled and the framerate hovering at ~60?
Because that's two entirely seperate scenarios.
Increased 60Hz lag on 240Hz+ monitors is usually caused by a fixed scanrate (see: viewtopic.php?f=5&t=3441&start=490#p51937), so it would indeed be odd if it was creating the same input lag increase in an 280Hz/60 FPS VRR scenario.
Only frametime should increase with ~60 FPS (or any lower FPS) at 280Hz in VRR mode.
That's my guess, but who knows. Again, they're not being clear enough in their explanation.PixelDuck87 wrote: ↑27 Jul 2020, 10:43Also, I'm wondering, won't "low framerate compensation" prevent the monitor from going 60hz so that 280hz VRR is out of the question which means they would have to set the monitor to 60hz for their messurments?
I had no idea that's how freesync/gsync works, I always thought it would directly change the refresh rate of the monitor on the fly...jorimt wrote: ↑27 Jul 2020, 11:37
Contrary to common understanding, VRR doesn't actually "change" the refresh rate, at least, the actual scanout time of the panel. That remains fixed at the currently set max physical refresh rate. So if it's set to 60Hz, regardless of VRR "refresh" rate or framerate, each frame will be scanned in at 16.6ms. Similarly, for 280Hz VRR, each frame will be scanned in at 3.6ms.
What VRR does change is how many times the scanout cycle repeats in a second. So if you have 280Hz VRR at 60 FPS, there are 60 scanout cycles completed per second, but each is still completing at the 280Hz rate of 3.6ms, whereas if you have 60Hz VRR at 60 FPS, there are also 60 scanout cycles completed per second, but each scanout cycle is now completing in 16.6ms.
Again, 60Hz input lag increase on 240Hz+ panels is usually limited to the physical 60Hz refresh rate due to the scanout conversion, and doesn't apply to VRR, as 60 FPS VRR at 280Hz is still technically a physical refresh rate of 280Hz, so no conversion is required.
I guess it still could be possible on that particular model, but I personally wouldn't know of a technical reason why.
